LDAP For Operators login
  • 1.  LDAP For Operators login
    Posted Mar 29, 2013 05:08 PM
    I was trying to set this up like we did on our Clearpass Guest class but im unable...
    Do we have to do somethign on the AD to make this work?
    Im trying this on the Clearpass Server
    Server URL:ldap://172.16.3.31/ou=Users,ou=Grupos_Usuarios,dc=abc,dc=local
    bind dn = putting a user with domain administrative rights
    bind password= the password of that user
    i get this error
    LDAP Bind failed: Invalid credentials (80090308: LdapErr: DSID-0C0903C5, comment: AcceptSecurityContext error, data 52e, v23f0), bind DN was: cdelarosa
    do i need to activate something on the AD to make this work? or i need  soemthign else?
  • 2.  RE: LDAP For Operators login
    Posted Mar 31, 2013 02:48 PM
    "AcceptSecurityContext error, data 52e" means: invalid credentials.  This means your username or password is incorrect.
    If you are sure your password is correct, try specifying the DN of the bind user, instead of just the username.
  • 3.  RE: LDAP For Operators login
    Posted Mar 31, 2013 03:13 PM
    You mean like this?
    CN=cdelarosa,CN=Users,CN=Colaboradores,DC=abc,DC=local
    the user is cdelarosa
    its contained on
    Users
    Sub OU = Colaboradores
    The domain is abc.local
    Im sure the pasword is correct... i even copy and pasted it to be sure i was typing it correctly
    Error
  • 4.  RE: LDAP For Operators login
    Posted Mar 31, 2013 06:32 PM
    Are you using any special characters in the password... :;>)+ there was a known issues with binding with a special character.  Try using a simple password and see if the fixes the issue
    From the Release Notes
    "Domain join operations will fail if the domain password contains special characters such as a space,
    quotes, or a “$” symbol."
  • 5.  RE: LDAP For Operators login
    Posted Mar 31, 2013 07:13 PM
    Hello Arnold i already tried that...
    My password had a dot  i mean .
    i made a new user without any character in the password didnt work either...
    The configuration doesnt seems to be hard
    On the server URL
    Thats the ip of the domain controller
    Users is the OU that contain the group of the operators i designed which is cpoperators, inside that group my username is the one that belongs to that group
    now on the BN
    CN=cpoperator,CN=Users,DC=abc,DC=local
    cpoperator is the user im using to authenticate,  it is inside the ou Users in the domain abc.local
    Isnt that correct?
    I am missing something?
    I could even join to the domain with no issue with my user name...
  • 6.  RE: LDAP For Operators login
    Posted Apr 01, 2013 04:56 PM
    Maybe you need "OU=Users" rather than "CN=Users" ?
    Check your DN very carefully.
  • 7.  RE: LDAP For Operators login
    Posted Apr 03, 2013 09:15 PM
    I got it correctly on the amigopod server i just made a typo when i was putting the message...
    So thats not it :(
  • 8.  RE: LDAP For Operators login
    Posted Apr 04, 2013 09:00 PM
    You were right Amigodave
    The guy on the tac did a dsquery  which solve it
    But it was not that i was putting the wrong DN because i was putting my user name as my login name like cdelarosa
    Instead it was Carlos De La Rosa
    CN=Carlos De La Rosa,OU=Colaboradores,OU=Users,DC=abc,DC=local
    I was using
    CN=cdelarosa,OU=Colaboradores,OU=Users,DC=alternetworks,DC=local
    At the end was this last thing my bad! i should have checked with dsquery.
    Anyways Thanks Amigodave
  • 9.  RE: LDAP For Operators login
    Posted Sep 03, 2013 04:11 PM
    Thanks tarnold for quoting the release notes to us -- I hadn't noticed that line.
    Banged my head for a day before I though to look for an authentication error from CP to AD.
