Aruba3600 on version 6.2.1.4
Trying to configure LDAP (Windows domain) management access to a domain group. I'm using this http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/Using-LDAP-AD-account-to-login-into-the-7210-Controllers/m-p/160048 as guide.
LDAP connection is fine (tested on Diagnostics tab, AAA Test Server)
When trying to add an attribute to Server Rules, memberOf doesn't show up in the dropdown.
What would be the CLI command for doing the same ?
You would just type in memberOf
Ahaa
Not the best GUI design choice (combo box and free input)
Works great, thank you !!
Dieter,
If you have a suggestion on how it could be made better, please submit one to the Ideas Portal.
List all possible entries in the combo box
OR
Eliminate the combo box and document all possible values the field can contain.
The latter is probably the best. It's very hard to find information like this...
