LDAP management authentication not working
This thread has been viewed 16 times
  • 1.  LDAP management authentication not working
    Posted Oct 28, 2015 04:27 PM
    We are running into some weird issues trying to use LDAP authentication on our controller.  Watching the logs, it is binding successfully, but as soon as we try to do a AAA test, or try a query-user, it timeouts, unbinds, and never successfully rebinds.  Below is the log with the initial conection and the test.
    We are running 6.4.2.10 on our controller.
    Oct 27 17:29:54 :124004:  <DBUG> |authmgr|  group "ldap_server" instance "AD-Intra" changed ..2.........
    Oct 27 17:29:54 :109011:  <INFO> |authmgr|  LDAP Server AD-Intra: Binding Admin to server
    Oct 27 17:29:54 :109000:  <DBUG> |authmgr|  LDAP Server AD-Intra: Sent Bind request to server
    Oct 27 17:29:54 :109012:  <NOTI> |authmgr|  LDAP Server AD-Intra: Admin Bound successfully
    Oct 27 17:30:20 :124004:  <DBUG> |authmgr|  Auth server 'AD-Intra' response=2
    Oct 27 17:30:20 :124004:  <DBUG> |authmgr|  server_cbh (462)(DEC) : os_auths 0, s AD-Intra type 3  inservice 0 markedD 0 sg_name
    Oct 27 17:30:20 :124004:  <DBUG> |authmgr|  Select server for method=, user=marshgbsd, essid=<>, server-group=, last_srv AD-Intra
    Oct 27 17:30:20 :199802:  <ERRS> |authmgr|  server_group.c, ncfg_server_getnext:382: Unknown or empty server group "" (method=, user=marshgbsd)
    Oct 27 17:30:20 :109000:  <DBUG> |authmgr|  LDAP Server AD-Intra: Server down callback.
    Oct 27 17:30:20 :109013:  <WARN> |authmgr|  LDAP Server AD-Intra: Connectivity lost to the Server, trying to re-establish
    Oct 27 17:30:20 :124004:  <DBUG> |authmgr|  LDAP: ldap_client_server_down_cb/1171 setting server AD-Intra out of service
    Oct 27 17:30:20 :109017:  <INFO> |authmgr|  LDAP Server AD-Intra: Setting Server Out of Service
    Oct 27 17:30:20 :124004:  <DBUG> |authmgr|  LDAP unbind: ldap_client_set_out_of_service
    Oct 27 17:30:20 :109018:  <INFO> |authmgr|  LDAP Server AD-Intra: Unbinding Admin Context from the server
    Oct 27 17:30:20 :109019:  <INFO> |authmgr|  LDAP Server AD-Intra: Unbinding User Context from the server
    Oct 27 17:30:20 :109015:  <INFO> |authmgr|  LDAP Server AD-Intra: Starting Timer to rebind to server in 1500 ms
    Oct 27 17:30:20 :109000:  <DBUG> |authmgr|  LDAP Server AD-Intra: Timer handler to bind to server
    Oct 27 17:30:20 :109000:  <DBUG> |authmgr|  LDAP Server AD-Intra: initializing LDAP structure for host:ldap-server-ip sslport:636
    Oct 27 17:30:20 :109000:  <DBUG> |authmgr|  LDAP Server AD-Intra: Initializing TLS Options
    Oct 27 17:30:20 :109000:  <DBUG> |authmgr|  LDAP Server AD-Intra: preferred connection type 1
    Oct 27 17:30:20 :109007:  <INFO> |authmgr|  LDAP Server AD-Intra: Admin - LDAPS connection established successfully to port 636
    Oct 27 17:30:20 :109000:  <DBUG> |authmgr|  LDAP Server AD-Intra: Setting ASYNC callback option
    Oct 27 17:30:20 :109000:  <DBUG> |authmgr|  LDAP Server AD-Intra: Setting timeout to 5 seconds
    Oct 27 17:30:20 :109000:  <DBUG> |authmgr|  LDAP Server AD-Intra: Initialization completed succssfully
    Oct 27 17:30:20 :109000:  <DBUG> |authmgr|  LDAP Server AD-Intra: Setting server-down callback
    Oct 27 17:30:20 :109001:  <DBUG> |authmgr|  LDAP Server AD-Intra: Initialization completed successfully
    Oct 27 17:30:20 :109011:  <INFO> |authmgr|  LDAP Server AD-Intra: Binding Admin to server
    Oct 27 17:30:20 :109000:  <DBUG> |authmgr|  LDAP Server AD-Intra: Sent Bind request to server
    Oct 27 17:30:20 :109015:  <INFO> |authmgr|  LDAP Server AD-Intra: Starting Timer to rebind to server in 60000 ms
  • 2.  RE: LDAP management authentication not working
    Posted Nov 04, 2015 06:25 PM
    Looks you have ldap-s configured
    If your LDAP server is not setup for ldap-s, you should try regular ldap and cleartext, instead
  • 3.  RE: LDAP management authentication not working
    Posted Nov 04, 2015 06:37 PM
    I have tried checking the box for "Allow Clear-Text" and changing the "Preferred Connection Type" to clear-text, and it has not made a difference.  I see the same results with the initial bind and the timeouts.
  • 4.  RE: LDAP management authentication not working
    Posted Nov 04, 2015 06:42 PM
    Start simple. Do not set it up for management authentication. Just setup an ldap server and under the diagnostic tab, do a AAA test-server using pap. Post the logs from that exchange. Make sure you use cleartext.
  • 5.  RE: LDAP management authentication not working
    Posted Nov 04, 2015 06:44 PM
    Test your setting with LDAP browser here:  http://www.ldapadministrator.com/download.htm to make sure all of your parameters are correct.  LDAP is case sensitive.
  • 6.  RE: LDAP management authentication not working
    Posted Nov 04, 2015 07:00 PM
    I have tested the credentials and setup with LDAP Administrator, and everything appears to be working.  I was able to browse the directory with the credentials I'm using in the controller.
    Here is what I see before I run an authentication test:
    (GBaruba7005) #show aaa authentication-server ldap AD-Intra status
    LDAP Server Table
    LDAP Server Attribute        Value
    Priority                     2
    Name                         AD-Intra
    Hostname                     server-ip
    AuthPort                     389
    AuthSSLPort                  636
    Retries                      3
    Timeout                      20
    AdminDN                      CN=testuser,OU=Group,DC=Our,DC=Domain,DC=Here
    AdminPasswd                  *****
    BaseDN                       DC=Our,DC=Domain,DC=Here
    KeyAttribute                 sAMAccountName
    Filter                       (objectclass=*)
    Allow Cleartext              yes
    Status                       Enabled
    InService                    Up
    InitDone                     yes
    AdminBound                   yes
    Connection Type              clear text
    Server Down                  no
    Marked For Delete            no
    In Use Callback Set          no
    Outstanding Authentications  0
    RebindTimerSet               no
    RebindCount                  0
    ReqViolationCount            0
    Here is what I see when I run the test
    (GBaruba7005) #aaa test-server pap AD-Intra testuser password
    AAA server timeout
    And here is what I see after I run the test (for 60 seconds)
    LDAP Server Table
    Priority                     2
    Name                         AD-Intra
    Hostname                     server-ip
    AuthPort                     389
    AuthSSLPort                  636
    Retries                      3
    Timeout                      20
    AdminPasswd                  *****
    Allow Cleartext              yes
    Status                       Enabled
    InService                    Up
    InitDone                     no
    AdminBound                   no
    Connection Type              unknown
    Server Down                  yes
    RebindTimerSet               yes
    RebindCount                  2
    ReqViolationCount            0
    It looks like everything is binding properly, and then I run the test, it times out, and it disconnects.
    Edit:  Removed domain specific information
  • 7.  RE: LDAP management authentication not working
    Posted Nov 04, 2015 07:25 PM
    Got it working with some help.  Had to change the Base-DN to the distinguishedName of the user minus the CN.  It started working right away.  Still odd that it doesn't work with the base DN though...
