Leap Issue Second
  • 1.  Leap Issue Second
    Posted Jun 03, 2015 02:44 PM
    HI All,
    Regarding this
    http://community.arubanetworks.com/aruba/attachments/aruba/unified-wired-wireless-access/49619/1/ARUBA-PFB-20150430_Leap_Second_Field_Bulletin_Rev-3.0511.pdf
    In our enviroment we have 3 Masters Controllers and 23 local controllers. Should I proceed to disable the NTP of each of the controlling server before June 30 and re-activate the July 1 to avoid any abnormality? All controllers have AOS 6.3.1.8
    What are the risks of not take the recommended actions?
    Thanks in advanced.
  • 2.  RE: Leap Issue Second
    Posted Jun 03, 2015 10:57 PM
    To avoid any issue, yes, disable NTP.  What hardware models are you running?
  • 3.  RE: Leap Issue Second
    Posted Jun 11, 2015 10:19 AM
    We have differents models:
    3200
    600
    650
    7002
    3400
    But, no problem, we will to proceed to disable the NTP server according with aruba's recommendations.
    Thanks a lot!
  • 4.  RE: Leap Issue Second
    Posted Jun 11, 2015 12:02 PM
    Blanca Nieto,
    NTP servers are only defined on the master controllers and pushed to the locals when you save the configuration.  You would just need to remove the NTP servers on the 3 masters and save the configuration.
