LED lights in AP 515
This thread has been viewed 23 times
  • 1.  LED lights in AP 515
    Posted Jan 02, 2020 12:51 PM
    we are installing new AP515 devices in our building and found a weird issue. some of the AP515 have there LED lights on while others are off. all APs are active and working and in the same group. some one told us that you can adjust the LEDs per Ap and not per AP group. is that true and if so where is this controlled? this is an issue because it is adding time to the install to see if the AP is up and active.
    thank you
  • 2.  RE: LED lights in AP 515
    Posted Jan 02, 2020 02:48 PM
    Which Leds are on and which ones are off?
    Leds are turned on and off based on the ap-led command.
  • 3.  RE: LED lights in AP 515
    Posted Jan 02, 2020 02:51 PM
    both lights on one of the AP 515 are off and the other AP 515 both lights are on. this would be the system and radio lights on the side of the AP
  • 4.  RE: LED lights in AP 515
    Posted Jan 06, 2020 01:32 AM
    Note that in addition to a software setting (on / off / blink), the LEDs can also be toggled between normal (SW defined) and off mode by (shortly) pressing the AP reset button.
    I'm not sure this works on all AP models and have not verified this on an AP-515, but it may be worth checking that.
