Legacy 802.11b
  • 1.  Legacy 802.11b
    Posted Nov 04, 2013 07:58 AM
    Hello to all
    I have a network with 3400 parent and want to remove the legacy 802.11b.
    My question is, I just removing basic rates 1, 2, 5 and 11 (DSSS) 802.11g I can already guarantee that these devices will not connect over the network? Unchecking these fees I have to enable the other, such as 6, 9, 12 ... If I disable these basic rates will not interfere with the other protocols? as 802.11g, n.
    I saw some threads about it but never became clear.
    It is also important to clear the transmission rates below 6?
    Thanks!
    #3400
  • 2.  RE: Legacy 802.11b
    Posted Nov 04, 2013 08:42 AM
    You are correct.  Just make sure 6 and 12 are ticked off.  on BOTH transmit AND basic rates.
  • 3.  RE: Legacy 802.11b
    Posted Nov 04, 2013 08:57 AM
    - Removing those should not allow the .11b wireless to connect
    - You should enable air fairness
    - Make sure you test this before you implement it globally since some .11n don't behave properly when you remove the lower data rates specially in a roaming event.
  • 4.  RE: Legacy 802.11b
    Posted Nov 04, 2013 11:33 AM
    So to ban legacy devices and allow everyone else to G, N can put my rates table as the basic annexed?
    The issue of roaming devices with low  rate in N really is a case to analyze, thanks for the reminder. Now if I leave the legacy and only prevent some transmission rates degrade the environment can only limit the transmission in any of above 6?
    Thx
  • 5.  RE: Legacy 802.11b
    Posted Sep 25, 2014 11:56 PM
    Hey there,
    How do i get to the Basic rate page option ? I have been souring the GUI for the function but to no avail.
    *I am using IAP 225
  • 6.  RE: Legacy 802.11b
    Posted Sep 26, 2014 12:00 AM
    Under the SSID profile on the advanced tab. ( Configuration > All Profiles > Wireless LAN > SSID)
