Wired Intelligent Edge
Legacy Cisco IP Phones on ArubaOS-CX
This thread has been viewed 39 times
  • 1.  Legacy Cisco IP Phones on ArubaOS-CX
    Posted Oct 20, 2020 01:12 PM
    Hey all,
    We recently got our first ArubaOS-CX switch in (Aruba 6300) and I'm having trouble getting our old Cisco 7960 IP phones working properly after the following commands:
    cdp enable
    vlan 5
    vlan 10
    voice
    int 1/1/1
    no shutdown
    no routing
    vlan trunk native 5
    vlan trunk allowed 5,10
    power-over-ethernet pre-std-detect
    exit
    At first, the phones will come up fine, and the access port will work and be on the correct VLAN for a desktop connected to the phone. However, after a couple of minutes, the phones will then revert to, "Configuring IP," and never move past that. The connected desktop still works fine. It's as if some timer expired relevant to the phone's VLAN/connectivity. The only relevant log I can see are these lines repeating (1/1/48 is the untagged vlan1/trunk/uplink port):
    2020-10-20T14:47:52.692106-04:00 Test-ArubaSw cdpd[3056]: Event|8904|LOG_INFO|MSTR|1|CDP neighbor f8:60:f0:03:7c:50 is updated on 1/1/48
    2020-10-20T14:48:24.676675-04:00 Test-ArubaSw cdpd[3056]: Event|8904|LOG_INFO|MSTR|1|CDP neighbor 00:14:1c:80:77:ab is updated on 1/1/1
    2020-10-20T14:48:52.720337-04:00 Test-ArubaSw cdpd[3056]: Event|8904|LOG_INFO|MSTR|1|CDP neighbor f8:60:f0:03:7c:50 is updated on 1/1/48
    2020-10-20T14:49:25.337655-04:00 Test-ArubaSw cdpd[3056]: Event|8904|LOG_INFO| Throttled 1 Messages
    Anyone run into this? Am I not configuring a VoIP port correctly for ArubaOS-CX?
  • 2.  RE: Legacy Cisco IP Phones on ArubaOS-CX
    Posted Oct 23, 2020 09:45 PM
    configuration looks correct, what CX version of code are you running?
    whats the output of  "show mac-address-table vlan 10" ?
  • 3.  RE: Legacy Cisco IP Phones on ArubaOS-CX
    MVP GURU
    Posted Oct 24, 2020 05:03 AM
    What do you have on log of Cisco IP Phones ?
