legasy device not able to connect WPA2-AES
  • 1.  legasy device not able to connect WPA2-AES
    Posted Feb 18, 2015 11:24 AM
    hi all,
    One more question.
    I have one SSID with WPA2auth and AES encryption enabledand auth server as AD [dont have CPPM].
    Today i was trying to authenticate one legasy device [nokia 5800] with that SSID, but its saying EAP-peap authentication failed.
    Is there anything to support legasy device with wpa2 -aes And also how can i troubleshoot why the client showing EAP-PEAP auth failed..
  • 2.  RE: legasy device not able to connect WPA2-AES
    Posted Feb 18, 2015 11:26 AM
    Turn on user-debugging for the client and then run "show auth-tracebuf mac
    <CLIENT-MAC>"</CLIENT-MAC>
  • 3.  RE: legasy device not able to connect WPA2-AES
    Posted Feb 18, 2015 11:52 AM
    Since this device only supports b/g try the following:
    - Make sure that all your lower basic rates are enabled
    - Create a test SSID with the same aaa profile and disable "band steering" on the VAP
  • 4.  RE: legasy device not able to connect WPA2-AES
    Posted Feb 18, 2015 12:00 PM
    Band steering is disabled, and all the lower rates is also enabled
    [Edit]  here is the O/P
    Feb 18 06:07:21  station-up             *  00:25:48:c0:1f:89  00:24:6c:b2:2d:c0  -  -  wpa2 aes
    Feb 18 06:07:21  eap-id-req            <-  00:25:48:c0:1f:89  00:24:6c:b2:2d:c0  1  5
    Feb 18 06:07:21  eap-start             ->  00:25:48:c0:1f:89  00:24:6c:b2:2d:c0  -  -
    Feb 18 06:07:21  station-down           *  00:25:48:c0:1f:89  00:24:6c:b2:2d:c0  -  -
    Feb 18 06:07:32  station-up             *  00:25:48:c0:1f:89  00:24:6c:b2:2d:c0  -  -  wpa2 aes
    Feb 18 06:07:32  eap-id-req            <-  00:25:48:c0:1f:89  00:24:6c:b2:2d:c0  1  5
    Feb 18 06:07:32  eap-start             ->  00:25:48:c0:1f:89  00:24:6c:b2:2d:c0  -  -
    Feb 18 06:07:32  station-down           *  00:25:48:c0:1f:89  00:24:6c:b2:2d:c0  -  -
    Feb 18 06:08:01  station-up             *  00:25:48:c0:1f:89  00:24:6c:b2:2d:c0  -  -  wpa2 aes
    Feb 18 06:08:01  eap-id-req            <-  00:25:48:c0:1f:89  00:24:6c:b2:2d:c0  1  5
    Feb 18 06:08:01  eap-start             ->  00:25:48:c0:1f:89  00:24:6c:b2:2d:c0  -  -
    Feb 18 06:08:01  station-down           *  00:25:48:c0:1f:89  00:24:6c:b2:2d:c0  -  -
  • 5.  RE: legasy device not able to connect WPA2-AES
    Posted Feb 18, 2015 11:57 AM
    how to turn on user debug....
    plz tell me
  • 6.  RE: legasy device not able to connect WPA2-AES
    Posted Feb 18, 2015 11:59 AM
    Logging level debugging user-debug <client-mac>
  • 7.  RE: legasy device not able to connect WPA2-AES
    Posted Feb 18, 2015 12:05 PM
    thanks Tim,
    here is the O/P
  • 8.  RE: legasy device not able to connect WPA2-AES
    Posted Feb 18, 2015 12:20 PM
    Can that device connect to an open SSID ?
  • 9.  RE: legasy device not able to connect WPA2-AES
    Posted Feb 18, 2015 12:22 PM
    Yeah it able to connect Open network, Captive portal, PSK.
    her eis the O/P of tracebuf
  • 10.  RE: legasy device not able to connect WPA2-AES
    Posted Feb 18, 2015 06:35 PM
    It looks like the client is not responding with its identity. Can you
    confirm that this device supports WPA2-Enterprise?
  • 11.  RE: legasy device not able to connect WPA2-AES
    Posted Feb 18, 2015 09:07 PM
    Yes, its supports WPA2, It has the option to select WPA2-AES [MSCHAPv2]
  • 12.  RE: legasy device not able to connect WPA2-AES
    Posted Feb 18, 2015 09:21 PM
    Did you load the Radius Server's Server Certificate on the device?  https://www.lrz.de/services/netz/mobil/802_1x/eduroam_S60v5_en/
  • 13.  RE: legasy device not able to connect WPA2-AES
    Posted Feb 18, 2015 12:26 PM
    Yes its able to connect open n/w , captive portal, psk,
    Here is the output of tracebuf
  • 14.  RE: legasy device not able to connect WPA2-AES
    Posted Feb 18, 2015 12:33 PM
    yes its able to connect with open, captive portal, psk.
    here is the o/p of tracebuf
    Auth Trace Buffer
  • 15.  RE: legasy device not able to connect WPA2-AES
    Posted Feb 18, 2015 12:35 PM
    yeah its able to connect to open, captive portal, psk N/W without issue..
    here is the output of tracebuf.
    Auth Trace Buffer
    sent from my android.
  • 16.  RE: legasy device not able to connect WPA2-AES
    Posted Feb 18, 2015 12:50 PM
    Yeah its able to connect Open , captive portal, psk .
    here is the output of the tracebuf
    Auth Trace Buffer
