Lesson Learned: Firmware mismatch on multiple IAPs
  • 1.  Lesson Learned: Firmware mismatch on multiple IAPs
    Posted Apr 04, 2015 03:27 AM
    I just received two IAPs (a 205 and a 215) and hooked them into a S1500-12P switch.
    Super annoying: I setup the IAP-215 as the primary VC, but the IAP-205 just would not show up, and would just reboot constantly.
    The IAP-215 had 6.4.2.0-4.1.1.0_45444 preloaded
    The ISP-205 had 6.4.2.0-4.1.1.0_46028 preloaded
    I upgraded both to 6.4.2.3-4.1.1.3_48994 and now both are visible from the GUI. Hooray.
    But c'mon, when I click on "Check For New Version" it says there are none. What gives?
    Anywho, hope this helps someone in the future.
    #AP205
  • 2.  RE: Lesson Learned: Firmware mismatch on multiple IAPs
    Posted Apr 06, 2015 09:33 AM
    Those are the same version, the 205 should have discovered the 215 VC.
    The "check for new version" checks the cloud and sometimes takes a few weeks before a new release is available in the cloud.
