let an adhoc network work.
  • 1.  let an adhoc network work.
    Posted Oct 15, 2013 08:14 AM
    Hi
    We have a adhoc network, for example its ssid is SSID1, it works on g-band.
    I want to have this adhoc network functioning. while i want other adhoc networks to be detected and protected from it.
    so, i have the  options "Detect Adhoc Networks" and "Protect from Adhoc Networks" turned on in the "IDS Unauthorized Device profile"
    My needed adhoc network SSID1 is having issues to work on the vicinity of the APs in the infrastructure. however the same adhoc network works fine away from the infrastructure APs.
    Any suggestions, on how i could have my needed adhoc network working. My infrastructure controller should not do any IDS activity on the needed adhoc network.
  • 2.  RE: let an adhoc network work.
    Posted Oct 15, 2013 08:41 AM
    Make sure you don't wireless containment on .
    You can also create an IDS rule that include that SSID as valid :
    (controller) (config) #ids ?
    ap-classification-rule  IDS AP Classification Rule profile
     http://www.arubanetworks.com/techdocs/ArubaOS_61/ArubaOS_61_CLI/ids.htm
  • 3.  RE: let an adhoc network work.
    Posted Oct 30, 2013 01:51 AM
    Hi Victor,
    I am not able to set a ibss network as valid.
    (OAW-4604) #show wms ap list | include network1
    d8:c7:c8:c7:27:a3 2 02:26:c6:06:61:a5 network1 62 165 0 interfering 2 open yes
    d8:c7:c8:cc:e4:fc 2 02:26:c6:06:61:a5 network1 27 191 1036 interfering 2 open yes
    (OAW-4604) #
    (OAW-4604) #wms ap 02:26:c6:06:61:a5 mode valid
    Valid classification not allowed for Adhoc (IBSS) AP
    Attachment(s)
    txt
    lab test.txt.txt   8 KB 1 version
  • 4.  RE: let an adhoc network work.
    Posted Nov 06, 2013 03:28 PM
    What AOS are you using ?
    I am able to do it with no issues
    (controller) #show  ap  monitor ap-list ap-name test-225-4
    Monitored AP Table
    bssid              essid             chan  ap-type      phy-type        dos      dt/mt          ut/it    encr            nstas  avg-rssi  curr-rssi  wmacs  ibss
    00:13:10:e2:c3:fe  brandeis_comcast  11    interfering  80211b/g        disable  32962/26877    586/14   wpa2-psk-aes    1      0         12         1      n
    (controller) #show  wms ap list | include comcast
    9c:1c:12:c0:92:b8  2      00:13:10:e2:c3:fe  brandeis_comcast           0     163  0     neighbor     0                     wpa2-psk-aes    no
    9c:1c:12:c0:93:22  2      00:13:10:e2:c3:fe  brandeis_comcast  16    174  1892  neighbor              1                                    wpa2-psk-aes    no
    9c:1c:12:c0:94:5c  2      00:13:10:e2:c3:fe  brandeis_comcast  46    186  0     neighbor     2                     wpa2-psk-aes    no
    9c:1c:12:c0:94:6a  2      00:13:10:e2:c3:fe  brandeis_comcast  32    178  2314  neighbor     1                     wpa2-psk-aes    no
    9c:1c:12:c0:94:9c  2      00:13:10:e2:c3:fe  brandeis_comcast  4     176  246   neighbor              0                               wpa2-psk-aes    no
    9c:1c:12:c0:94:a0  2      00:13:10:e2:c3:fe  brandeis_comcast  0     186  0     neighbor     0                                    wpa2-psk-aes    no
    9c:1c:12:c0:94:a8  2      00:13:10:e2:c3:fe  brandeis_comcast  6     176  2     neighbor     0                                   wpa2-psk-aes    no
  • 5.  RE: let an adhoc network work.
    Posted Nov 11, 2013 12:43 AM
    Hi Victor,
    The code in which i was working was 6.1.3.1, i did as well check in the 6.1.3.10.
    Working with the TAC, they mentioned its not possible to set an IBSS network as valid, and keep it away from being contained, while the other adhoc networks be contained.
    They suggested to make an feature request.
