lic-sec-2 no AP license?
  • 1.  lic-sec-2 no AP license?
    Posted Oct 14, 2015 07:21 AM
    Issue w/AP not joining...  Am I missing a license?  I only got two certificates to redeem but AP indicates unlicensed?
    (r8-aruba7005-1) #show license-usage ap
    AP Licenses
    Type                     Number
    AP Licenses               0
    RF Protect Licenses       2
    PEF Licenses             2
    Overall AP License Limit 0
    AP Usage
    Type             Count
    Active CAPs     0
    Standby CAPs     0
    RAPs             0
    Remote-node APs 0
    Tunneled nodes   0
    Total APs       0
    Remaining AP Capacity
    Type Number
    CAPs 0
    RAPs 0
    License Table
    Key                                               Installed   Expires Flags Service Type
    6IVM9ZDJ-54C/VhnH-QCrwNY43-M20+LXpV-ZPKQ5gVl-WTE 2015-10-12 Never     E     Next Generation Policy Enforcement Firewall Module: 2
                                                      10:50:18
    Men8iiEe-/MhWqM7+-OyBukkep-OmFmsWJx-t5U39FQk-WWg 2015-10-12 Never     E     RF Protect: 2
                                                     10:50:37
    License Entries: 2
    Flags: A - auto-generated; E - enabled; R - reboot required to activate
    (r8-aruba7005-1) #show keys
    Licensed Features
    Feature                                             Status
    Access Points                                       0
    RF Protect                                         2
    VPN Server Module                                   4096
    xSec Module                                         0
    Next Generation Policy Enforcement Firewall Module 2
    Advanced Cryptography                               0
    RF Protect                                         ENABLED
    Policy Enforcement Firewall                         ENABLED
    VPN Server                                         ENABLED
    xSec Module                                         DISABLED
    Policy Enforcement Firewall for VPN users           DISABLED
    Advanced Cryptography                               DISABLED
    Maritime Regulatory Domain                         DISABLED
    (r8-aruba7005-1) #show ap database
    AP Database
    Name               Group   AP Type IP Address   Status     Flags Switch IP     Standby IP
    9c:1c:12:ce:72:ca bxb-300 103     192.168.80.2 Up 8m:51s IL     192.168.88.2 0.0.0.0
    Flags: U = Unprovisioned; N = Duplicate name; G = No such group; L = Unlicensed
           I = Inactive; D = Dirty or no config; E = Regulatory Domain Mismatch
           X = Maintenance Mode; P = PPPoE AP; B = Built-in AP
           R = Remote AP; R- = Remote AP requires Auth; C = Cellular RAP;
           c = CERT-based RAP; 1 = 802.1x authenticated AP; 2 = Using IKE version 2
           u = Custom-Cert RAP; S = Standby-mode AP; J = USB cert at AP
           M = Mesh node; Y = Mesh Recovery
    Total APs:1
    (r8-aruba7005-1) #show log system 10 | include stm
    Oct 14 06:58:48 :399899: <INFO> |ipstm| sapi_rsp, sapi.c:248: SAPI response service/level lookup failed
    Oct 14 06:58:48 :348306: <DBUG> |ipstm| papi_rcv_cb, Recvd PAPI Message, len=88
    Oct 14 06:58:49 :348306: <DBUG> |ipstm| papi_rcv_cb, Recvd PAPI Message, len=88
    Oct 14 06:58:49 :399899: <INFO> |ipstm| sapi_rsp, sapi.c:248: SAPI response service/level lookup failed
    Oct 14 06:59:26 :305038: <WARN> |stm| No available license for AP 9c:1c:12:ce:72:ca
    (r8-aruba7005-1) #show ap database long
    AP Database
    Name               Group   AP Type IP Address   Status Flags Switch IP     Standby IP Wired MAC Address Serial #   Port FQLN Outer IP User
    9c:1c:12:ce:72:ca bxb-300 103     192.168.80.2 Down           192.168.88.2 0.0.0.0     9c:1c:12:ce:72:ca CU0081678       N/A   N/A
    Port information is available only on 6xx.
    Total APs:1
  • 2.  RE: lic-sec-2 no AP license?
    Posted Oct 14, 2015 11:10 AM
    The security license includes PEFNG and RFP, not AP. You'll need to add AP licenses.
    You should also consider using enterprise licenses in the future which include all 3 plus AirWave.
    Tim
  • 3.  RE: lic-sec-2 no AP license?
    Posted Oct 14, 2015 11:24 AM
    Does the AP license need to match the others two (2)?
  • 4.  RE: lic-sec-2 no AP license?
    Posted Oct 14, 2015 11:27 AM
    Yes. Licensing is least common denominator. If you have 6 RFP, 6 PEFNG and 1
    AP license installed, only 1 AP will come up.
