License AP aruba
  • 1.  License AP aruba
    Posted Jun 16, 2020 09:34 AM
    Hi All,
    Need help here. I have an license AP and PEF 114. RFP 100
    And in dashboard controller I have 102 active AP.
    my question, why license in " Licenses remaining availbility" not reduce  ?
    it showing 14 license available for AP and PEF
  • 2.  RE: License AP aruba
    MVP EXPERT
    Posted Jun 16, 2020 09:55 AM
    All of the license count must match for the number of APs you have. For example, if you have 100xAP, 100xPEF, 114xRFP you will be licensed to the smallest number, so only 100 APs will be licensed.
    In short, you should make sure you have the same quantity of every license type.
  • 3.  RE: License AP aruba
    Posted Jun 16, 2020 10:00 AM
    hi @craig_syme
    thanks for the reply
    dont have any solution  ?
    I dont need 14 lic RFP for those AP
  • 4.  RE: License AP aruba
    MVP EXPERT
    Posted Jun 19, 2020 12:22 PM
    Correct, for example:
    Total APs = 114
    Licenses required:
    114x AP
    114x PEF
    114x RFP
