License check failed for the command
  • 1.  License check failed for the command
    Posted Apr 24, 2014 10:17 AM
    I'm in the lab testing for my project, I had an AP up for about 2 weeks then all of a sudden the ap went down. I looked at the logs and this is what I saw:
    License check failed for the command, when processing the line#500::ip dhcp default-pool private
    Apr 24 08:30:19 :399818:  <INFO> |cfgm|  License check failed for the command, when processing the line#521::voip sip-midcall-req-timeout disable
    Thanks.
  • 2.  RE: License check failed for the command
    Posted Apr 24, 2014 10:35 AM
    You should probably open a TAC case
  • 3.  RE: License check failed for the command
    Posted Apr 24, 2014 11:32 AM
    The problem is when I connect the AP to one of our switches the ap receives an IP and works, it just doesn't work with one of our internall switches.
  • 4.  RE: License check failed for the command
    Posted Apr 24, 2014 12:05 PM
    What do you mean by internal switches?
