License Installation AOS 8
This thread has been viewed 22 times
  • 1.  License Installation AOS 8
    Posted Sep 19, 2019 06:06 AM
    I'm currently testing Aruba 8  with one VMM and one VMC .
    After installing an eval License (MC-VA-RW) on the MM (as I thought it would "transfer" licence to the MC) it seem that managed device is not allowed to use this license.
    "#show license usage-client" command return no use by any devices and "#show license server-table" command confirm that licenses are installed and enabled.
    I first tried to create a specific pool on the /md branch, but the VMC didn't get any license.
    I also try to move license from MM to MC but it seem it cannot be done with eval license.
    Should I ask new license and installe it on VMC instead of VMM or is there an other way ?
    Best Regards,
  • 2.  RE: License Installation AOS 8
    MVP EXPERT
    Posted Sep 19, 2019 06:40 AM
    To confirm you  need to install the VMC licenses at the /mm level. If you run 'show license debug' on the VMC, does it show the License Server IP as your MM? If you are on 8.0 also consider upgrading to a later release, there is been many fixes since this initial version.
  • 3.  RE: License Installation AOS 8
    Posted Sep 19, 2019 07:31 AM
    The command show license usage-client gives information on the clients associated.
    Since its a MM-MD test setup the command "show licence-usage AP" sheds more light on MM and MC-VA licenses in the output.
    Also what is the flag status of the licenses ? Is it 'E' or 'ER'. If it is the latter then a reboot is required.
    This can be checked using the command "show license".
  • 4.  RE: License Installation AOS 8
    Posted Sep 19, 2019 08:35 AM
    I'm currently working on ArubaOS (MODEL: ArubaMC-VA), Version 8.1.0.0.
    License server is configured as the MM :
    show license debug
    Summary of licensing state
    Centralized Licensing: Enabled
    Switch Role: Local
    License Role: License Client
    Master IP: 192.168.151.207
    Switch IP: 192.168.151.208
    License Server IP: 192.168.151.207
    License are only flagged with E, no reboot needed.
    Here is the result of  #show license-usage ap on managed device :
    AP Licenses
    Type Number
    AP Licenses 0
    MM Licenses 0
    MC-VA Licenses 20
    MC-VA country FR
    Controller License False
    Overall AP License Limit 0
    AP Usage
    Type Count
    Active CAPs 0
    Active RAPs 0
    Remote-node APs 0
    Tunneled nodes 0
    Total APs 0
    Remaining AP Capacity
    Type Number
    CAPs 0
    RAPs 0
    My Test AP is currently flag as Inactive and Unlicensed :
    test     305      172.16.36.237  Up 1m:25s  IL     192.168.151.208  0.0.0.0
    I also notice that the managed device has status "NO MM LICENSE" :
    (MM1) [mm] #show switches
    All Switches
    IP Address       IPv6 Address  Name      Location          Type    Model       Version        Status  Configuration State  Config Sync Time (sec)  Config ID
    192.168.151.207  None          MM1       Building1.floor1  master  ArubaMM-VA  8.1.0.3_61578  up      UPDATE SUCCESSFUL    0                       85
    192.168.151.208  None          MC1.V8.0  Building1.floor1  MD      ArubaMC-VA  8.1.0.0_59206  up      NO MM LICENSE        0                       85
    I just read from License Types and Usages that since Aruba 8.1, MM (MM-VA) License are needed to terminate controlers and AP.
    Here is license installed :
    License Server Table for pool / profile root
    Service Type                                        PoolSize  ExpiredLic  ActualPoolSize  UsedLic  RemainingLic  Warnings                FeatureBit
    Access Points                                       0         0           0               0        0             None                    enabled
    Next Generation Policy Enforcement Firewall Module  0         0           0               0        0             None                    disabled
    RF Protect                                          0         0           0               0        0             None                    disabled
    xSec Module                                         0         0           0               0        0             None                    disabled
    Advanced Cryptography                               0         0           0               0        0             None                    disabled
    WebCC                                               0         0           0               0        0             None                    disabled
    MM-VA                                               0         0           0               0        0             None                    enabled
    MC-VA-RW                                            980       0           980             0        980           Some licenses expiring  enabled
    MC-VA-EG                                            0         0           0               0        0             None                    enabled
    MC-VA-IL                                            0         0           0               0        0             None                    enabled
    MC-VA-JP                                            0         0           0               0        0             None                    enabled
    MC-VA-US                                            0         0           0               0        0             None                    enabled
    Can you confirm that I need in addition a MM-VA license in order to manage MD and terminate AP on them ?
    Regards
  • 5.  RE: License Installation AOS 8
    MVP EXPERT
    Posted Sep 19, 2019 09:40 AM
    You need an AP license to terminate an AP. You currently have 0 AP-LIC hence why the AP is showing as unlicensed.
    You also need a MM license for your Mobility Master as well, this is showing as 0.
    Here is a sample BOM for a Virtual MM, Virtual MC and AP, PEF and AirWave
  • 6.  RE: License Installation AOS 8
    Posted Sep 20, 2019 01:07 AM
    You might wanna add a PEFNG and RFprotect license as well and enable the feature bits(they are disabled from the output) if you plan on adding custom rules for your users.
