Let say i got 5 APS
I got 3 AP in AP mode
and 2 in air monitor mode
It is possible to buy 5 AP lic, 5 Pefng but 2 RFP license? because i ll use use the ips/ids on the air monitors? or i just want it to use there?
Cheers
Carlos
No, unfortunately you can't. Licensing uses least common denominator.
For features like spectrum, you can put a single RFProtect license on your master controller and move an AP over to the master when you want to use it for spectrum.
Just wanted to double check!
If the system were to operate like that, you'd have APs fighting for features and no way control who gets what.
