License question - RAP
  • 1.  License question - RAP
    Posted Nov 12, 2012 11:39 PM
    Hello:
    I need to know if i want to license two RAP-2 and two RAP-5 with AP License for 620 Wireless controller, and i want to license PEFNG for this four RAP also.
    Do i need only 1 AP License and 1 PEF-NG License???
  • 2.  RE: License question - RAP
    Posted Nov 13, 2012 06:34 AM
    You need 2 AP and 2 PEF-NG.
  • 3.  RE: License question - RAP
    Posted Nov 13, 2012 09:23 AM
    Hello Colllin
    i would like to know how this works
    Does this mean that i can use 1 AP license and 1 Penf license IF all the remote APS are from the same model?
    Example
    if i got 4 AP license  on the WC and im already using 3 on the campus APS i get 1 free licesnse
    With that AP license if i have 4 rap 2 i can use that free license for those remote APS and also 1 PEnf licnse for those 4 rap 2
    But then  if i got 2 rap 2 and 2 rap 5 then icannot do that  because they are from different moddels so ill need another ap licsne and another penf licence
    did i get it correctly?
    Cheers
    Carlos
  • 4.  RE: License question - RAP
    Posted Nov 13, 2012 09:41 AM
    Our licensing model is is simple. One controller based AP, regardless of type (CAP or RAP) or model requires one license of each type you need to use.
    If you have a total of 4 APs (regardless of type) you need qty. 4 AP licenses.
    If you want to add PEFNG to the controller that is managing 4 APs you need qty. 4 PEFNG
    If you want to add RFProtect to the controller that is managing 4 APs you need qty. 4 RFP
    Assuming the above example with AP, PEFNG, and RFP a shortfall on any of the license types will result in one of the four APs not being able to come on line due to the shortage and the AP status will be "IL" (inactive due to a license isssue).
  • 5.  RE: License question - RAP
    Posted Nov 13, 2012 10:00 AM
    Okay i undertood that its clear but i got one more quetsion for you Marcus
    if i got a 620 WC
    This accept 8 Campus APs
    and 32 RAPs
    Thats is what the documentation says
    Scenario 1
    i got let say 8 Campus APS so im using 8 campus APS so i need here 8 AP licnse and 8 penf lincense
    In this same scenario let say i want to add 4 RAPS i need to buy here 4 licesnes for APs and 4 more licenses of PENf for those
    At the end ill ahve in that 620
    8 Campus APS and 4 RAPS   is this correct? total APS 12 APS on the 620
    When it says that the 620 got limitation of 8 APS it means 8 Campus APS?
    We are a lilttle confused here and well im  we are trying to understand this correctly to quote it correctly
    Thanks in advance for the asnwer
    Cheers
    CArlos
  • 6.  RE: License question - RAP
    Posted Nov 13, 2012 10:11 AM
    First thing is to keep licensing separate from capacity then stick to the "1 license per AP regardless of type" rule :)
    The 620 can do 620 8 CAP or 32 RAP or some combination in between -- there is a 1:4 ratio of CAP to RAP.  With that in mind, if you use 8 CAP you can add 0 RAP,  decrease CAP to 7 you can do 4 RAP, decrease CAP to 6 and you can do 8 RAP, etc.
  • 7.  RE: License question - RAP
    Posted Nov 13, 2012 10:20 AM
    Okay just to be sure and sorry for bothering too much Marcus cause i know i am
    let say i got 7 CAmpus APS and i got 4 RAPS thats for the capacity(ill be no able to add more APS neither rap or cap in this situation)
    For the licensing
    i would need a total of 12 license for APS and12 licnese for PENF in this 620 controller
    I am correct on this example?
  • 8.  RE: License question - RAP
    Posted Nov 13, 2012 10:29 AM
    7 CAP + 4 RAP = 11 APs
    If you need PEFNG you would need:
    - qty. 11 AP licenses
    - qty. 11 PEFNG licenses
  • 9.  RE: License question - RAP
    Posted Nov 13, 2012 10:30 AM
    Haha sorry yeah 11 license not 12 ;)
