Licenses on the Aruba controllers.
  • 1.  Licenses on the Aruba controllers.
    Posted Nov 15, 2015 07:36 AM
    What are all the license feature we can use with the Aruba controllers? So far we only know and are using the Access point and the policy enforcement firewall license.
    N
  • 2.  RE: Licenses on the Aruba controllers.
    Posted Nov 15, 2015 08:01 AM
    Have a look at the Working with Licenses section of the User Guide:
    • Base OS: base operating functions including VPN and VIA clients.
    • AP Capacity: capacity license for RAP indoor and outdoor Mesh APs. Campus, Remote, or Mesh APs can terminate on the controller without the need for a separate license.
    • Advanced Cryptography (ACR): this license is required for the Suite B Cryptography in IPsec and 802.11 modes. License enforcement behavior controls the total number of concurrent connections (IPsec or 802.11) using Suite B Cryptography.The xSec license features are bundled with this license.
    • Content Security Service (CSS): enables the Cloud-based Content Security service on your controller. This license is administered based on the number of users.
    • Policy Enforcement Firewall Virtual Private Network (PEFV): enables Policy Enforcement Firewall for VIA clients. This is a controller license.
    • Policy Enforcement Firewall Next Generation (PEFNG): Wired, WLAN Licensed per AP numbers including user roles, access rights, Layers 4 through 7 traffic control, per-service prioritization/QoS, authentication/accounting APIs, External Service Interfaces (ESI), Voice and Video. This is an AP count license.
    • Public Access: reserved for future use.
    • RFProtect: Wireless Intrusion Protection (WIPS) and Spectrum Analysis. This is an AP count license.
    • xSec (Extreme Security) for Federal: Layer 2 VPN for wired or wireless using FIPS-approved algorithms.
    • Internal Test Functions: for internal use only.
    The AP and PEFNG licenses are the most common; followed by the RFP license.
  • 3.  RE: Licenses on the Aruba controllers.
    Posted Nov 15, 2015 10:05 PM
    Thanks Mate!!
    How can the RFP license enhance our Wireless usage? I am more interested on the Spectrum Analysis part.
    Are there some country specific restrictions for the usage?
    Do I need this license for Rouge AP blocking also?
    N.
  • 4.  RE: Licenses on the Aruba controllers.
    Posted Nov 16, 2015 01:26 AM
    Yes Sir you need it for dealing with rogues. If you have the RFP license you also have WIPS ability as it is a two fold license that enables Spec An and WIPS.
  • 5.  RE: Licenses on the Aruba controllers.
    Posted Nov 16, 2015 08:44 AM
    Have a look at the RFProtect Datasheet and Wireless Intrusion Protection Technology Guide for more info.
