Licensing quetions clearpass HA
  • 1.  Licensing quetions clearpass HA
    Posted Mar 26, 2018 12:33 PM
    Hello
    If i got a clearpass  5k 6.6   with 1k guest
    And i got another clearpass and i put it in HA and just the first clearpass has the 1k guest license
    What would happen if that server fails? it will not send the 1k guest license to the other server like in the controller for 30 days right?
    I guess it will work just fine for a few weeks then it will lock me out of the administration it is like that?
  • 2.  RE: Licensing quetions clearpass HA
    Posted Mar 27, 2018 11:46 AM
    Anyone???
    Cheers
    Carlos
  • 3.  RE: Licensing quetions clearpass HA
    Posted Mar 27, 2018 12:29 PM
    The ClearPass Guest license is a cluster wide license and shared by all the nodes in the cluster (even when you install/add it on the publisher). When publisher is down, the 1K license will still be available for rest of the subscribers in the cluster.
  • 4.  RE: Licensing quetions clearpass HA
    Posted Mar 27, 2018 12:31 PM
    Thank you!
    Cheers
    Carlos
  • 5.  RE: Licensing quetions clearpass HA
    Posted Apr 04, 2018 09:30 AM
    Hello Saravanan
    Last quetion
    This would be the same in clearpass 6.7?
    Let say the client got clearpass 5k Hardware appliance 6.6
    i upgrade it to clearpass 6.7  so i get 5000 acess license in that clearpass
    I buy a NEW hardware appliance with 6.7 without license for the HA
    IS this the way to go right? i mean, i dont need to buy any license if i already got it from the old clearpass if im just using the second clearpass for the HA right?
    Cheers
    Carlos
  • 6.  RE: Licensing quetions clearpass HA
    Posted Apr 04, 2018 02:40 PM
    Yes this would be the same, the cluster license pooling haven't changed in 6.7.X
    Also have a look to the ClearPass 6.7 License Conversion Technote in support.arubanetworks.com tech notes for all the details :)
  • 7.  RE: Licensing quetions clearpass HA
    Posted Apr 04, 2018 03:29 PM
    for the HA right?
    In 6.7 licensing in a cluster is a bit different for Policy manager
    licenses which are now Access Licenses , prior to 6.7 if you had a node
    with 500 licenses those weren't share across the cluster but in 6.7 Access
    Licenses are shared across all nodes.
    So if you decide to add more nodes (HW or Virtual) for redundancy /
    capacity to the cluster you don't need to purchase additional licensing
