Limit Device On Clearpass
  • 1.  Limit Device On Clearpass
    Posted May 17, 2016 04:39 AM
    Hi All,
    I need your help, I have install Clearpass and intgrated with AD. How to limit device per user Max 1 Device for any group???
    Kindly need your help
    Thank you in advance
  • 2.  RE: Limit Device On Clearpass
    Posted May 18, 2016 02:30 AM
    What do you mean by group? AD groups? Device types?
    What do you mean by limit? Only a single device can be given access? Or one device at a time? Or one device per day/week/month?
    The answer is probably yes, but with these unknown factors it is difficult to say.
    It might be good if you elaborate a bit and explain the scenario you'd like to have with some examples.
  • 3.  RE: Limit Device On Clearpass
    Posted May 18, 2016 02:42 AM
    Hi Mr. Robers,
    I mean one device at a time,
    Example : I login with Group IT using Laptop, and then I Can't connect with other device. And when i disconnect from my laptop i can connect by Phone or other.
    The core is 1 user 1 Device at a time.
    Best Regards,
    Sandi Pradana
    System Engineer
    PT. Helios Informatika Nusantara (a member of CTI Group)
    Mobile : +62 877 8303 1491
    Email : sandi.pradana@helios.id
    [1459480518220_HIN.jpg]
  • 4.  RE: Limit Device On Clearpass
    Posted May 18, 2016 03:07 AM
    If you want to limit concurrent sessions for the same user to 1 session only, you can use the Session-Check for that. It is used in the template for Guest access and also on Aruba Solution Exchange in the guest scenarios.
    And it should work for non-guest as well. Please work with your partner to get this scenario worked out.
