Limit max Download
  • 1.  Limit max Download
    Posted Aug 06, 2019 03:00 PM
    Hello everyone,
    There is any way that I can limit the download of the users in a daily basis with Instant AP, for example, that every user can download up to 1 Gb of data every day ? Or maybe a max duration of the connection per day, for example 2 hours of daily use ?
  • 2.  RE: Limit max Download
    Posted Aug 06, 2019 07:41 PM
    no you cant do that just with Instant AP. IAPs can provide BW control restriction like Mbps.
    However you can provide download quota using Aruba ClearPass
  • 3.  RE: Limit max Download
    Posted Aug 06, 2019 10:29 PM
    Thank you ariyap, I have another doubt, can I make restrictions like the ones on this example
    https://www.arubanetworks.com/techdocs/ClearPass/6.6/PolicyManager/Content/CPPM_UserGuide/Enforce/EPSession_Restrictions.htm#Examples
    Session Duration: The User/Endpoint is allowed access to the network daily for three hours in a specified time period (between 9:00 a.m. and 5:00 p.m.)
     Session-Check > Allowed-Duration = 3
     Session-Check >Duration-Units = Hours
     Session-Check > Check-Type = Daily
     Session-Check > Start-Time = 09:00:00
     Session-Check Stop-Time = 17:00:00
     Post-Auth-Check > Action = Disconnect
    But with Instant or a Controller solution ?
  • 4.  RE: Limit max Download
    Posted Aug 06, 2019 11:35 PM
    yes you can do that if you have ClearPass. The link that you shared is  from ClearPass user guide.
    By the way the current version of ClearPass is 6.8.x
  • 5.  RE: Limit max Download
    Posted Aug 07, 2019 11:18 AM
    Hello ariyap, but the is any way that I can do that kind of restriction on the SSID using only Aruba Instant or a controller solution ?
