Limit number of UE's per Standalone AP
  • 1.  Limit number of UE's per Standalone AP
    Posted Jun 19, 2016 02:05 PM
    Hello Dears,
    Is it possible to limit the number of associated UE's per a standalone AP? Meaning not connected to a controller, and no AirWave installed..
    Reason is we want to limit them to 60 ~ 80 UE's per Outdoor AP, and the controller & AirWave will be installed later on.
    The used AP is the outdoor AP-270, (Not the instant model).
    Thanks.
  • 2.  RE: Limit number of UE's per Standalone AP
    Posted Jun 19, 2016 02:09 PM
    What is a UE?
  • 3.  RE: Limit number of UE's per Standalone AP
    Posted Jun 19, 2016 08:29 PM
    Hello Cappalli,
    UE is User Equipment = Subscriber associated to an AP
  • 4.  RE: Limit number of UE's per Standalone AP
    Posted Jun 19, 2016 02:18 PM
    I think he means UserEndpoint. But how to install a AP-27x (no instant) as standalone AP? Not possible as far as I see it.
    Perhaps use the IAP version and then limit the user amount per SSID.
  • 5.  RE: Limit number of UE's per Standalone AP
    Posted Jun 19, 2016 03:45 PM
    For OP, a controller is required before deploying any (non-IAP) AP-270s. At which point you can then set a limit on the number of users per radio.
  • 6.  RE: Limit number of UE's per Standalone AP
    Posted Jun 19, 2016 08:49 PM
    Thanks jhoward, I have some queries please:
    Do you mean the controller here for (non-IAP) is mandatory to operate? Or this is to be able to limit number of users per Radio?
    The wanted scenario is:
    > 1-3 Mesh Clustered Outdoor (non-IAP) AP's will connect with EoGRE to a WiFi Mobility Gateway, as follows (Mesh AP's <(EoGRE)> TWG <> GW Router <> Firewall <> Internet)
    > This is only for Pilot Phase, but final one will have a Controller installed.
    > Limit the number of users per AP to ~ 60 for 2.4GHz (5 GHz will be used for backhauling).
    Thanks.
  • 7.  RE: Limit number of UE's per Standalone AP
    Posted Jun 19, 2016 08:59 PM
    Yes. You need a controller for them to operate.
  • 8.  RE: Limit number of UE's per Standalone AP
    Posted Jun 19, 2016 09:16 PM
    I need more clarification for separate points:
    > As per my understanding they can operate with (non-IAP) and without controller, if no limitation is required for number of subscribers.
    > But to limit number of users, this will require Instant AP or a controller.
    Thanks.
  • 9.  RE: Limit number of UE's per Standalone AP
    Posted Jun 19, 2016 09:21 PM
    No, if it's a regular AP (non-Instant), you need a controller.
    You can limit the number of associated clients on both Instant and controller.
