Limit Single SSID to a Certain AP in Aruba Network
This thread has been viewed 19 times
  • 1.  Limit Single SSID to a Certain AP in Aruba Network
    Posted Dec 22, 2012 10:56 AM
    How can you Limit a Single SSID to an AP , Example Guest SSID available in Conference Room AP only.
  • 2.  RE: Limit Single SSID to a Certain AP in Aruba Network
    Posted Dec 22, 2012 11:25 AM
    Create a new AP-Group (configuration> Wireless> AP Configuration).  Go to that new AP group under wireless lan> Virtual AP.  Click on Add to add the Guest Virtual AP.  Next, provision the access point you want to only broadcast the guest network to that AP-Group (configuration> Wireless> AP Installation> Provision.  Select the AP you want to change>  Change the AP Group and Click on Reprovision).  The AP will reboot into that AP group and only broadcast the Virtual APs you specified.
  • 3.  RE: Limit Single SSID to a Certain AP in Aruba Network
    Posted Dec 22, 2012 12:30 PM
    Excellent Solution ,Thanks , it working perfectly has i wanted
  • 4.  RE: Limit Single SSID to a Certain AP in Aruba Network
    Posted Dec 29, 2015 05:25 AM
    HI,
    For an instant environment running on 6.4.2.
    I can't find a configuration> Wireless> AP Configuration in the virtualcontroller webinterface. Has this changed? How is done now?
    Basically I want to deactivate all SSIDs for the preferred master to reduce the load on that AP.
  • 5.  RE: Limit Single SSID to a Certain AP in Aruba Network
  • 6.  RE: Limit Single SSID to a Certain AP in Aruba Network
    Posted Apr 04, 2016 06:31 AM
    i follow the same procedure but Still Guest SSID broadcasting by all AP
    i have 7205 controller x 2  Version 6.4.3.1
    thanks
    hope to hear soon
  • 7.  RE: Limit Single SSID to a Certain AP in Aruba Network
    Posted Apr 04, 2016 06:45 AM
    Did you create a new group with the Guest VAP only? Did you provision the AP with that AP Group afterwards?
    Could you please elaborate a bit more your query/question with more information so we can help you?
    Regards
    Borja
  • 8.  RE: Limit Single SSID to a Certain AP in Aruba Network
    Posted Apr 04, 2016 06:57 AM
    yes i did but the problem is i provision one AP with that AP group, that AP is now broadcasting only Guest SSID but still all AP are broadcasting that Guest SSID
    how can i stop all other AP to broadcast Guest SSID
    i need only one AP to broadcast Guest SSID, i have assigned all AP to Default AP group
    do i need to create again AP group and put all AP to that Group except That one particular AP
    or ?
    thanks.
    Regard
    Tej Bahadur
  • 9.  RE: Limit Single SSID to a Certain AP in Aruba Network
    Posted Apr 04, 2016 07:03 AM
    So basically you have 2 AP-Groups :1 AP provisioned with AP-Group B (only Guest VAP) and the remaining APs with AP-Group A (some VAP's plus Guest VAP), right?
    If you remove Guest VAP from AP-Group A, you will only broadcast Guest VAP on the AP provisioned with AP-Group B.
    If this is not clear, could you please let us know what VAP's you have under AP-Group A and B?
    Regards
    Borja
  • 10.  RE: Limit Single SSID to a Certain AP in Aruba Network
    Posted Apr 04, 2016 07:13 AM
    i need to delete or Remove that Guest SSID from Default AP-Group i guess , because i created New AP-Group and i put that particular AP to that AP-Group,
    now that AP is only broadcasting only that Guest SSID
    but when i go to Default-AP group i don't see either Remove or Delete that SSID from Default SSID
    any idea or i should create new AP-Group
    Regard
    Tej Bahadur
  • 11.  RE: Limit Single SSID to a Certain AP in Aruba Network
    Posted Apr 04, 2016 07:19 AM
    it seems now stop that AP broadcasting because i just uncheck that  Guest_VAP_prof  >  enable virtual AP check box
    Thanks.
    Regard
    Tej Bahadur
  • 12.  RE: Limit Single SSID to a Certain AP in Aruba Network
    Posted Apr 04, 2016 07:26 AM
    @tejen_bhandari wrote:
    it seems ok now because i just uncheck that  Guest_VAP_prof  >  enable virtual AP check box
    Thanks.
    Regard
    Tej Bahadur
    if you have disabled the VAP, you are not broadcasting the Guest SSID in the AP you wanted to. Enable it again and follow what I wrote in the previous post.
  • 13.  RE: Limit Single SSID to a Certain AP in Aruba Network
    Posted Apr 04, 2016 07:54 AM
    i'm done now !!!!!    yeap now it is ok
    thanks alot
    Regard
    Tej Bahadur
  • 14.  RE: Limit Single SSID to a Certain AP in Aruba Network
    Posted Apr 04, 2016 07:23 AM
    You need to remove the VAP from the AP-Group. You don't need to delete the SSID profile.
    show ap-group NAME-OF-THE-DEFAULT-GROUP // this default group is the one that you have used to provision all the AP's.
    you will see the Virtual-AP's added to that Group.
    If your VAP is called Guest_VAP
    conf t
    no virtual-ap Guest_VAP
    Regards
    Borja
