Wired Intelligent Edge
Limit traffic across VLAN
  • 1.  Limit traffic across VLAN
    Posted Jan 30, 2020 09:05 AM
    Hi all...I'm new to the Aruba world and was wondering if I can limit the type of traffic that goes across VLAN's?  I've got an Aruba 3810M with VLAN's and routing all setup.  Now, for example, let's say that I want clients on VLAN100 to RDP to a host on VLAN200.  I ONLY want RDP traffic and maybe ICMP, nothing else.
    Can this be accomplished only with the 3810M?
    Thanks!
  • 2.  RE: Limit traffic across VLAN
    MVP GURU
    Posted Jan 31, 2020 02:36 AM
    Thanks!
    yes, it is possible using ACL
  • 3.  RE: Limit traffic across VLAN
    Posted Feb 04, 2020 11:08 AM
    Yes this is possible with the help of ACL. you can limit the traffic across the VLAN's
    Please let me know if you have any questions.
  • 4.  RE: Limit traffic across VLAN
    Posted Feb 04, 2020 11:15 AM
    Is there a good resource on how to implement ACL's?
  • 5.  RE: Limit traffic across VLAN
    Posted Feb 05, 2020 03:49 AM
    You can refer to the below documentation for the implementation of ACL.
    https://techhub.hpe.com/eginfolib/Aruba/16.09/5200-5908/index.html#c_IPv4_Access_Control_Lists_ACLs.html
    Raghu
    Please give me kudos if my post was useful!
    If your issue is solved mark the post as solution!
