For our guest wireless I have 100mb user-role, that once youv'e accepted the captive portal, you share the 100mb with the rest of the users.
My question is, can I then rate each user to 5mbps within the 100mb user-role?
You can enable a per user limit in the role. So you could give each user 5mb. I assume this is a controller based deployment? If so see below.
http://www.arubanetworks.com/techdocs/ArubaOS_64x_WebHelp/Content/ArubaFrameStyles/Firewall_Roles/User_Roles.htm#firewall_roles_981653125_1048695
You can assign a bandwidth contract to provide an upper limit to upstream or downstream bandwidth utilized by clients in this role. You can select the Per User option to apply the bandwidth contracts on a per-user basis instead of to all clients in the role.
Is it possible to limit per user and have an overall cap? This link is just telling me I can do EITHER role, group, or user
