Limiting connected time
  • 1.  Limiting connected time
    Posted Jun 29, 2015 01:30 PM
    Hi Guys,
    We are developing a project using IAP + ClearPass (PM + Guest) where a public Wifi network the user will self-registration and they can use the network for 1 hour. After this 1 hour they will be disconnected and only can connect again after 2 hours. It's possible? The network will be Captive Portal on Clearpass.
    Best Regards,
    Paulo Raponi
  • 2.  RE: Limiting connected time
    Posted Jun 29, 2015 01:39 PM
    Yes its possible.
    You have to add CPPM as radius 3576 server in IAP, and you have to configure CPPM to send Radius CoA [disconnect mesage]after one one hour and after that you can put the user in blacklist for 2 hour.
