Limiting users in IAP
  • 1.  Limiting users in IAP
    Posted Feb 19, 2015 03:19 AM
    Is there a way to limit the client per IAP, [like 20 users per IAP].
    We are using IAP 105 with CPPM.
  • 2.  RE: Limiting users in IAP
    Posted Feb 19, 2015 05:36 AM
    Hi Rana,
    It is possible to set the threshold for the Clients. we can set the value in "Wlan settings --> Advanced settings" . we can set the value from 1-255 and the default value will be 64.
    You can refer IAP User Guide for this feature.
    For your ref :
    Please feel f ree for any further help on this.
  • 3.  RE: Limiting users in IAP
    Posted Feb 20, 2015 09:06 PM
    just to clarify:
    the limitation is per Radio  Per SSID
    so for exemple
    if you limite the user number to 64 , you can go to 64 users in 2.4 Ghz and 64 users in 5 Ghz  (a total of 128)
    and don't forget it is per SSID
