limits to show ap debug auth-trace-buf
  • 1.  limits to show ap debug auth-trace-buf
    Posted Dec 23, 2015 04:56 AM
    Is there a way to make the number of lines shown with show ap debug auth-trace-buf higher?
    Or can i somehow log these lines to an external server? I have set all categories to debug for syslog, but don't see it.
    Anything else possible?
    It is a useful command, but in a busy enviroment it becomes difficult to get the transaction from the client you are looking for.
  • 2.  RE: limits to show ap debug auth-trace-buf
    Posted Dec 23, 2015 06:57 AM
    You cannot limit the number of lines, or send it to syslog but if you turn on user debug only for a few specific clients, the output will only be limited to those clients:
    (Aruba7005-US) #configure t
    Enter Configuration commands, one per line. End with CNTL/Z
    (Aruba7005-US) (config) #logging level debugging user-debug de:ad:be:ef:ca:fe
    (Aruba7005-US) (config) #show debug
    DEBUG LEVELS
    Facility    Level      Debug Value        Sub Category  Process
    user-debug  debugging  de:ad:be:ef:ca:fe  N/A           N/A
    (Aruba7005-US) (config) #exit
    (Aruba7005-US) #show auth-tracebuf
    Warning: user-debug is enabled on one or more specific MAC addresses;
             only those MAC addresses appear in the trace buffer.
    You would then use something like airrecorder to periodically collect the output of show auth-tracebuf.
  • 3.  RE: limits to show ap debug auth-trace-buf
    Posted Dec 24, 2015 05:21 AM
    thanks cjoseph, this is about Instant so i believe the logging level user-debug isn't possible? it just collects it for everyone?
    ill look into the airrecorder, sounds useful.
  • 4.  RE: limits to show ap debug auth-trace-buf
    Posted Dec 24, 2015 07:16 AM
    Correct, on instant the auth-tracebuf shows all devices.  You would use airrecorder to script running that command on the IAP  at intervals to get the whole picture.
