An example: 1G optical link running between two switches. On one side auto negotiation is disabled, on another side it is enabled. Signal strength is good. Both ports are administratively up, but line protocol is down, because of this mismatch.
Another example: VPN protocols often signal their issues to the upper protocols by putting the virtual interface 'Link protocol: DOWN'.
While your example with Frame Relay is valid, I am afraid line protocol has nothing to do with STP (there all ports are UP, some are just not forwarding, blocked). Also you never use Layer 3 directly, you always have Layer 2 protocol and physical media.
Ivan Bondar
Original Message:
Sent: Jan 19, 2023 10:01 PM
Subject: Line Protocol Down
Nowadays people are using STP less and less.
Frame relay is also obsolete.
Sometimes they just use layer 3 directly.
So are there any circumstances in which line protocol is down is encountered in real life?
