Link aggregation 7005 vs. 54xxzl
  • 1.  Link aggregation 7005 vs. 54xxzl
    Posted Mar 15, 2017 01:11 PM
    Hi there,
    I configured in a testlab our 7005 with ArubaOS 8.0.1.0 57205 (is there any newer out there?) with some AP315 and enterprise-WPA2 with RADIUS-Auth.
    Everything is fine so far. Now I want to get this into production and for that I wish to aggregate all 4 Gigabit-ports to the main switch HPE 5412zl.
    Setting up a static trunk does not work at all.
    Using LACS I was not really able to get it up and running again:
    I can manage the controller, the APs do connect to master, they do broadcast the SSID - but connecting to that WLAN takes more than 10s and after beeing connected there is not really traffic flowing.
    The configuration is as follows:
    interface gigabitethernet 0/0/0
        description "GE0/0/0"
        trusted
        trusted vlan 1
        no poe
        no spanning-tree
    interface gigabitethernet 0/0/1
        description "GE0/0/1"
        trusted
        trusted vlan 1
        no poe
        no spanning-tree
    interface gigabitethernet 0/0/2
        description "GE0/0/2"
        trusted
        trusted vlan 1
        no poe
        no spanning-tree
    interface gigabitethernet 0/0/3
        description "GE0/0/3"
        trusted
        trusted vlan 1
        no poe
        no spanning-tree
    interface port-channel 0
        add gigabitethernet 0/0/0
        add gigabitethernet 0/0/1
        add gigabitethernet 0/0/2
        add gigabitethernet 0/0/3
        trusted
        trusted vlan 1
        switchport trunk allowed vlan 1-4094
    interface vlan 1
        ip address 192.168.0.254 255.255.254.0
    no uplink wired vlan 1
    no uplink enable
    ip default-gateway 192.168.0.99
    ip nexthop-list load-balance-gateways
    I did manually set "lacp group 0 mode active" to the gigabit-interfaces which does not made any difference.
    On 54xxzl-side there is only defined "LACP status "Passive""
    Could someone give an advice, please?
    Thanks!
  • 2.  RE: Link aggregation 7005 vs. 54xxzl
    Posted Mar 15, 2017 03:10 PM
    The way you currently configured is to use static
    If you want to use lacp on the controller side you need configure it this way:
    trusted
    trusted vlan "VLANS"
    lacp timeout short
    trusted
    lacp timeout short
    trusted
    lacp timeout short
    trusted
    lacp timeout short
    trusted
    switchport mode trunk
    switchport trunk allowed vlan "VLANS"
  • 3.  RE: Link aggregation 7005 vs. 54xxzl
    Posted Mar 15, 2017 04:03 PM
    Hi Victor,
    thank you for your input.
    Meanwhile the only thing I did is rebooting the 7005 - and now config is shown like this:
        trusted
        trusted vlan 1
        no poe
        no spanning-tree
        trusted
        trusted vlan 1
    (OK, the "switchport mode trunk" for port channel 0 I added just right now).
    So why my config does not change reproduceable by
    #write memory
    Do I really have to reboot the whole controller?
    And I was wondering, too, that after my initial configuration via GUI just eth 0+1 did show "mode: PC-0" - eth 2+3 still were shown as "access".
    Even after removing them from PC-0 and rejoining I had to change the state via CLI.
    So the question is: is there any newer realease of ArubaOS than mine?
    Thanks again - F.One
    I cannot confirm that the things are now working as expected because I´m at home now and just connected via VPN.
