Comware
Link Aggregation between HP FlexFabric 5700 and Cisco Switches
  • 1.  Link Aggregation between HP FlexFabric 5700 and Cisco Switches
    Posted Mar 06, 2017 09:26 AM
    Hi there,
    We are trying to link together our Cisco Distrinution switches to new Hp Flex Fabrics that we will have at our datacentre and so far we are struggling with getting this to work.
    The switches that we have are 2 x HP FlexFabric 5700 and 4 Cisco 3750.
    The initial idea was to trunk? ports 1/0/39,  1/0/40, 2/0/39, 2/0/40 to 4 ports on the Cisco's using GBIC modules. The only VLAN that will need to be accessible is VLAN 40.
    Can anyone guide me please on how i could achieve this? everything that I have seemed to try so far hasn't worked.
    Cheers
    #HP
    #cisco
    #.Aggregation
    #Trunk
    #LACP
    #VLAN
  • 2.  RE: Link Aggregation between HP FlexFabric 5700 and Cisco Switches
    Posted Mar 06, 2017 08:53 PM
    Hello!
    You need something like this:
    SW_5700
    interface Bridge-aggregation 1
    link-aggregation mode dynamic
    interface gigabitEthernet 1/0/1
    port link-aggregation group 1
    interface gigabitEthernet 1/0/2
    ######Link Aggregation using LACP######
    SW_3750
    interface port-channel 1
    interface gigabitEthernet 1/10
    channel-group 1 mode active
    interface gigabitEthernet 1/11
    Run the command below on HPE swtich and see if it has established the communication:
    display link  aggregation verbose
    Note: To avoid looping, connect the cables after configuration.
    Note: The vlan configuration must be done on aggregation and not on the port individually
  • 3.  RE: Link Aggregation between HP FlexFabric 5700 and Cisco Switches
    Posted Mar 08, 2017 06:09 AM
    Great thanks, this helped us a lot! who knew that you had to do things in certain order and not o define VLANS on the actual ports.
  • 4.  RE: Link Aggregation between HP FlexFabric 5700 and Cisco Switches
    MVP GURU
    Posted Mar 08, 2017 08:45 AM
    Not specifically relevant to HP Comware based <--> Cisco IOS based link aggregation (indeed it is relevant to HP Comware based switches <--> HP ProVision based switches link aggregation configuration) but exactly to the order of execution of various Port Trunking configuration steps deployed on Comware based switches: see here (read the "A-Series" paragraph), also Port Trunking steps are explained on the Switch documentation (IIRC Management and Configuration Guide).
    Note the initial statement "When configuring a link aggregation on A-Series switches (Comware) the order of execution is very important".
