Link Aggregation betweet 5406 and 7210
  • 1.  Link Aggregation betweet 5406 and 7210
    Posted Jul 10, 2018 04:31 PM
    I was wondering if the configuration is this one before putting it
    Actual config is
    Core is a alcatel switch which i got a static link aggregation configured
    On the 7210 i got this
    interface port-channel 3
            add gigabitethernet 0/0/0
            add gigabitethernet 0/0/1
            trusted
            trusted vlan 1-4094
            switchport mode trunk
            switchport trunk allowed x,y,z
    Now we are putting a 5406
    trunk C11-C12 trk3 lacp
    trunk C9-C10 trk4 lacp
    My question is if i should use lacp at the end or trunk, im thinking it lacp but im not sure
    Cheers
    Carlos
  • 2.  RE: Link Aggregation betweet 5406 and 7210
    MVP EXPERT
    Posted Jul 10, 2018 06:28 PM
    Lacp correct, in recommend always use lacp because its a ieee standard.
    Dont confuse at the term “trunk”, i
    Trunk on a aruba switch we means to aggeregate interfaces. But trunk isnt a ieee standard and work different betweens vendors, so use always lacp if you cab because its a ieee standard.
    Trunk on aruba controllers, hpe a-series and cisco switches we mean with trunk that there are more vlans tagged on a interface. Do this have nothing to do with aggregate interfaces.
    Conclusion.... your right to use lacp as you did.
