Link Flapping with ArubaOS 5
  • 1.  Link Flapping with ArubaOS 5
    Posted May 02, 2013 09:39 AM
    wow, finally we have now upgraded from 3.1.x.x and 3.2.x.x to 5 on our Alcatel-Lucent OAW-4324 Controllers (Aruba 2400?).
    The Controllers are connected directly to a Juniper SSG Firewall (e.g. SSG 140). Since the upgrade to 5.0.4.8 the uplink port on the firewall goes down every 2-3 minutes for about 10 seconds, than comes up again. On the second partition we have 3.4.5.1 running. After Booting into this partition the problem disappears.
    In short this problem exists only after booting into partition with 5.0.x.x. On WLAN Controller the logs don't show link up down event. But on Firewall the interface really goes down.
    Running here 2 controllers in this scenario with the same issue. Another OAW-4324, uplink connected to an Alcatel-Lucent AOS Switch, doesn't have this problem!
    What could be the problem, where to start Troubleshooting?
    I think this problem isn't related to Juniper SSG since this problem doesn't exist after booting to older firmware 3.4.5.1?!
    Thanks in advance,
    Tobias Hachmer
  • 2.  RE: Link Flapping with ArubaOS 5
    Posted May 02, 2013 09:57 AM
    How do you have those interfaces configured , just a trunk / static port-channels / LACP ?
    What AOS 5 code are you running ?
  • 3.  RE: Link Flapping with ArubaOS 5
    Posted May 02, 2013 10:06 AM
    You could run some  debugging commands on the controller to see what's happening :
    (controller) (config) #logging level debugging network
    (controller) (config) #logging level debugging system
    Then do
    (controller)# show log system all or show log network all
    And to see if there's any layer1 issues you could check if theres any errors on the interfaces
    (controller) #show port stats
    Port Statistics
    InputErrorBytes OutputErrorBytes CRCErrors
    (controller) #show  port link-event
  • 4.  RE: Link Flapping with ArubaOS 5
    Posted May 02, 2013 10:11 AM
    thanks for the reply.
    here the output:
     #show interface fastethernet 1/22
    FE 1/22 is up, line protocol is up
    Hardware is FastEthernet, address is 00:0B:86:43:2E:F7 (bia 00:0B:86:43:2E:F7)
    Description: fe1/22
    Encapsulation ARPA, loopback not set
    Configured: Duplex (Full), speed (100 Mbps)
    MTU 1500 bytes, BW is 100 Mbit
    Last clearing of "show interface" counters 0 day 6 hr 46 min 29 sec
    link status last changed 0 day 6 hr 44 min 37 sec
    9010 packets input, 681585 bytes
    Received 22 broadcasts, 0 runts, 0 giants, 0 throttles
    0 input error bytes, 0 CRC, 0 frame
    0 multicast, 8988 unicast
    21234 packets output, 1485730 bytes
    0 output errors bytes, 0 deferred
    0 collisions, 0 late collisions, 0 throttles
    This port is TRUSTED
    POE Status of the port is OFF
    #show interface fastethernet 1/22 switchport
    Switchport: Enabled
    Administrative mode: static access
    Operational mode: static access
    Administrative Trunking Encapsulation: dot1q
    Operational Trunking Encapsulation: dot1q
    Access Mode VLAN: 1810 (VLAN1810)
    Trunking Native Mode VLAN: 1 (Default)
    Trunking Vlans Enabled: NONE
    Trunking Vlans Active: NONE
    #show image version
    Partition : 0:0 (/dev/hda1)
    Software Version : AOS-W 5.0.4.8 (Digitally Signed - Production Build)
    Build number : 35054
    Label : 35054
    Built on : 2012-08-27 12:44:56 PDT
    Partition : 0:1 (/dev/hda2) **Default boot**
    Software Version : AOS-W 3.4.5.1 (Digitally Signed - Production Build)
    Build number : 31936
    Label : 31936
    Built on : 2012-01-16 11:24:21 PST
    Because of the Link Flapping Problem we switched back to 3.4.5.1 where the problem does not exist.
  • 5.  RE: Link Flapping with ArubaOS 5
    Posted May 02, 2013 11:01 AM
    You may want to open a TAC case or try upgrading to another AOS code.
    I couldn't find anything related to this on the 5.0.4.8 or 5.0.4.9 release notes.
    Do you have a manual speed/duplex setup or automatic ?
  • 6.  RE: Link Flapping with ArubaOS 5
    Posted May 03, 2013 02:34 AM
    Upgrading to another AOS code is not possible, the latest available is 5.0.4.8 for AOS-W.
    I have already tested 5.0.4.5, same issue.
    First the interfaces on both sides were at auto/auto. Setting the interfaces fix to 100/full haven't solved it.
    I won't obviate that this problem is related to the Juniper SSG Firewall. Maybe there was a change from 3.4.5.1 to 5.x.x.x. that raise this problem?!
    Anyone here who has Aruba Controller connected directly to Juniper SSG?
    Tobias Hachmer
