ย View Only
Link pool dhcp with ssid
This thread has been viewed 29 times
  • 1.  Link pool dhcp with ssid
    Posted Aug 15, 2024 11:15 AM
    Hello friends
    i have controller aruba 7010 with 14 Access Point , 14 SSID
    i have pool dhcp (Pool_Users) 172.16.11.0/24 linked 14 ssid in vlan11
    i want creat new Vlan50 subnet (172.16.50.0/24)
    i want creat new pool dhcp (Pool_New) linked 172.16.50.0/24 in Vlan50
    Total:
    Each AP has two SSID
    14 SSID : in Vlan 11 You take an IP from 172.16.11.0/24
    14 SSID : in vlan 50 You take an IP from 172.16.50.0/24
    Is this possible how to do this?
    Thanks in advance
  • 2.  RE: Link pool dhcp with ssid
    Posted Aug 15, 2024 12:49 PM
    If you are asking if you can have a single AP broadcast the same SSID twice, no, at least not on the same radio.
    If you are trying to add another VLAN to an existing WLAN, just create a VLAN pool with both VLANs specified and assign the pool to the WLAN.
    Carson Hulcher, ACEX#110
  • 3.  RE: Link pool dhcp with ssid
    Posted Aug 15, 2024 01:04 PM
    No same SSID
    I want to creat two SSID in Each AP
    Link ssid1 with vlan11 Pool_dhcp11
    Link ssid2 with vlann50 Pool_dhcp50
  • 4.  RE: Link pool dhcp with ssid
    Posted Aug 15, 2024 01:12 PM
    Yes.
  • 5.  RE: Link pool dhcp with ssid
    Posted Aug 15, 2024 01:17 PM
    Is this possible how to do this? pleez๐Ÿ™๐Ÿ™
  • 6.  RE: Link pool dhcp with ssid
    Posted Aug 15, 2024 01:24 PM
    There are multiple guides/videos/whatever on how to setup the WLAN already available.  You aren't asking for anything special or different, this is just a standard WLAN.
  • 7.  RE: Link pool dhcp with ssid
    Posted Aug 15, 2024 01:37 PM
    I know how to create pools Dhcp, Vlans and ssid wlan...
    The connection must be between Access Point and Port Trunk?
    My problem is that I suspect that when connecting the SSD to vlan50, what makes the device get an IP from pool50 and not the old pool11?
    I haven't tried it yet because I'm a new employee. I'm afraid I might make a mistake and mess up the settings.
  • 8.  RE: Link pool dhcp with ssid
    Posted Aug 15, 2024 01:44 PM
    First step is to get the client device on VLAN 50, that is easiest done by either allowing the VLAN configured on the VAP to apply or by using RADIUS to assign the VLAN.  You mention using a controller so I'm going to assume the traffic is tunneled.  For a tunneled WLAN the VLAN must be allowed to traverse one of the wired connections and the upstream switch has to be configured to span VLAN 50 where necessary.
  • 9.  RE: Link pool dhcp with ssid
    Posted Aug 15, 2024 01:55 PM
    Thank you very much. ๐Ÿ™๐Ÿ™
  • 10.  RE: Link pool dhcp with ssid
    Posted Sep 04, 2024 11:14 AM
    I did what you told me to do. But when converting a port to a trunk, the a.p. is turned off!!!
    Where is the problem please?
  • 11.  RE: Link pool dhcp with ssid
    Posted Sep 04, 2024 12:04 PM
    I didn't tell you to do anything, I pointed out what was required for functionality.
    1. Please stop cross-posting your same question to multiple boards.
    2. There is no need to open a new thread when you are already active in another.
    3. What version of AOS are you running?  Your screenshot is from AOS 6 which is EOL.
    4. I would recommend reaching out to your local HPE Aruba Networking account team and request assistance from your SE.  Other options: existing online guides/documents for basic setup or education services.
