Linksys PoE for AP-135
  • 1.  Linksys PoE for AP-135
    Posted May 01, 2014 02:21 PM
    I tried to use a standard Linksys PoE injector to power up an AP-135. They work well with the AP-65. I got a green light but nothing would happen. I don't know if something is wrong with the injector but wanted to see if there is a different power requirements  for the AP-135 that requires a different kind of injector.
    Thanks for your help,
  • 2.  RE: Linksys PoE for AP-135
    Posted May 01, 2014 02:35 PM
    Does the AP-135 require a PoE+ (802.3at) complient injector?
    Is it underpowered with a PoE (802.3af) complient injector?
  • 3.  RE: Linksys PoE for AP-135
    Posted May 01, 2014 02:45 PM
    It does not require a POE+ injector, but some lower-cost POE injectors do not put out the required amount of power at distance....
  • 4.  RE: Linksys PoE for AP-135
    Posted May 01, 2014 02:54 PM
    I appreciate your response.
    The AP-135 installation guide says it is 802.3at complient but says nothing about 802.3af.
    This has me confused and feeling unsure about the power requirements. Is there a reason it is documented in this manner?
  • 5.  RE: Linksys PoE for AP-135
    Posted May 01, 2014 03:46 PM
    I do not know about the documentation, but I know that power drops the longer the cable gets.  For enterprise manufacturers, they can be expected to provide full power over 300 feet.  For other non-enterprise manufacturer this is not the case.  I would just get a POE+ injector.  Either way, the combination of a consumer-grade 802.3af power injector and the AP-135 are not a good fit.
  • 6.  RE: Linksys PoE for AP-135
    Posted May 01, 2014 03:51 PM
    Thanks for your input :)
  • 7.  RE: Linksys PoE for AP-135
    Posted May 01, 2014 03:54 PM
    You are welcome.
