Linksys WUSB6100M cant connect to 2705A controller
  • 1.  Linksys WUSB6100M cant connect to 2705A controller
    Posted Mar 12, 2018 08:54 AM
    Hi
    i have an SSID that i cannot connect with this USB WiFi card
    the SSID is WPA2 Ent with PEAP (user/password)
    any known issues about it ?
    thanks
  • 2.  RE: Linksys WUSB6100M cant connect to 2705A controller
    Posted Mar 12, 2018 09:29 AM
    Is there an error message on the radius server?
    What options do you have enabled on that SSID?
  • 3.  RE: Linksys WUSB6100M cant connect to 2705A controller
    Posted Mar 12, 2018 09:38 AM
    Hi
    I dont have radius
    Its only user/password and after afew sec
    I just get unable to connext this network .
    I changed to another wifi card and it connrcted
    Get Outlook for Android
  • 4.  RE: Linksys WUSB6100M cant connect to 2705A controller
    Posted Mar 12, 2018 09:49 AM
    What operating system is the client computer?
  • 5.  RE: Linksys WUSB6100M cant connect to 2705A controller
    Posted Mar 12, 2018 09:50 AM
    Win10
  • 6.  RE: Linksys WUSB6100M cant connect to 2705A controller
    Posted Mar 12, 2018 09:53 AM
    How is the controller configured?
    What 802.11 options does the SSID have enabled?
    Are you using termination on the controller in the 802.1x profile?
    On the Windows client do you have "Validate Server Certificate" checked?
  • 7.  RE: Linksys WUSB6100M cant connect to 2705A controller
    Posted Mar 12, 2018 11:18 AM
    Hi
    this is what u mean ?
  • 8.  RE: Linksys WUSB6100M cant connect to 2705A controller
    Posted Mar 12, 2018 10:58 PM
    Yes.  What about the answers to the other questions?
  • 9.  RE: Linksys WUSB6100M cant connect to 2705A controller
    Posted Mar 13, 2018 03:58 AM
    Hi
    i think i found the problem . silly me
    since i have two auth before i login , one is the user name and the second one was the MAC and when i entered the mac i wrote it in CAPITAL :(
    now its connected
    thanks for the support
