Hi folks,
We've got a HP 5412zl chassis which manages all our VLAN config. We have a VLAN 15 set up for the VoIP network (Mitel IP phone system) which works fine from the 5412zl and other configurable switches we have connected to it (mostly Procurve 3500 series).
We recently picked up some HP 1820 switches and I'm struggling to get them to configure properly. Obviously we can set the same VLAN ID and pass the traffic that way, but the IP phones aren't picking up the proper config when plugged in to these switches.
Here's a copy of the config from the 5412zl for VLAN 15, minus all the tagged/untagged ports:
vlan 15
name "Voice"
qos dscp 101110
voice
exit
Is there a way to get these details passed on to the 1820 switch, either via LLDP-MED or other means, to make the switches work? I've had a look for how to configure LLDP-MED manually on the 5412zl but couldn't seem to find anything that worked. LLDP is enabled and running, but there's no config data for that VLAN.
Thanks in advance,
James
#lldp-med
