LMS IP
  • 1.  LMS IP
    Posted Oct 22, 2017 10:49 PM
     LMS IP must be consistent with Controller-IP ?
    thanks
  • 2.  RE: LMS IP
    Posted Oct 22, 2017 11:30 PM
    yes.
    Each access point will be managed by an aruba controller, whereby this switch will be noted as a LMS (local mobility switch)
    The IP of this switch will be also known as a LMS IP
