Wired Intelligent Edge
last person joined: 11 hours ago
Load balancing for dynamic segmentation
This thread has been viewed 27 times
  • 1.  Load balancing for dynamic segmentation
    Posted Oct 13, 2021 10:25 AM
    I am looking for details on how dynamic segmentation clients are load balanced on a controller cluster. All I have found is the switch configuration where the controller IP and a backup controller IP can be configured. In this way the wired clients are not load balanced. Does the cluster VRRP need to be configured for the load balancing to be enabled?
    Stewart Smith
  • 2.  RE: Load balancing for dynamic segmentation
    MVP GURU
    Posted Oct 13, 2021 12:43 PM
    No. If the controllers are clustered, the users will be load balanced.
    Dustin Burns
    Lead Mobility Engineer @WEI
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2021
  • 3.  RE: Load balancing for dynamic segmentation
    Posted Oct 13, 2021 01:30 PM
    The switch only supports having a physical gateway IP from the cluster.  Once you enter that in and enable the tunneling profile (ubt zone command), the switch will automatically download the cluster information and have high availability and load balancing ready from the cluster map (bucket list) downloaded from the cluster.  You can verify this with the "show ubt state" command.
    ubt zone corporate vrf default
    primary-controller ip 10.5.8.6
    enable
    Justin-6300# show ubt state
    Zone corporate:
    Local Conductor Server (LCS) State:
    LCS Type IP Address State Role
    Primary : 10.5.8.6 ready_for_bootstrap operational_primary
    Switch Anchor Controller (SAC) State:
    IP Address MAC Address State
    Active : 10.5.8.6 00:0b:86:b7:6a:7f registered
    Standby : 10.5.8.7 00:0b:86:dd:6c:00 registered
    Justin-6300# show ubt information
    Zone corporate:
    SAC Information :
    Active : 10.5.8.6
    Standby : 10.5.8.7
    Node List Information :
    Cluster Name : TME-Cluster
    Cluster Alias Name :
    Node List :
    10.5.8.6
    10.5.8.7
    Bucket Map Information :
    Bucket Map Active : [0...255]
    Bucket ID A-UAC S-UAC Connectivity
    0 10.5.8.6 10.5.8.7 L3
    1 10.5.8.6 10.5.8.7 L3
    2 10.5.8.6 10.5.8.7 L3
    3 10.5.8.7 10.5.8.6 L3
    4 10.5.8.6 10.5.8.7 L3
    5 10.5.8.6 10.5.8.7 L3
    6 10.5.8.7 10.5.8.6 L3
    7 10.5.8.6 10.5.8.7 L3
    8 10.5.8.6 10.5.8.7 L3
    9 10.5.8.6 10.5.8.7 L3
    10 10.5.8.6 10.5.8.7 L3
    11 10.5.8.7 10.5.8.6 L3
    12 10.5.8.6 10.5.8.7 L3
    13 10.5.8.6 10.5.8.7 L3
    14 10.5.8.6 10.5.8.7 L3
    Justin Noonan
  • 4.  RE: Load balancing for dynamic segmentation
    Posted Oct 14, 2021 03:33 AM
    Ok thanks. I don't see the ubt commands on the switch which is 2930M - does load balancing only work with CX? I didn't set this up so am not sure how load balancing would work. The current configuration is :
    tunneled-node-server
    controller-ip 10.x.x.20
    backup-controller-ip 10.x.x.21
    mode role-based reserved-vlan 4089
    sh tunneled-node-server
    Tunneled Node Server Information
    State : Enabled
    Primary Controller : 10.x.x.20
    Backup Controller : 10.x.x.21
    Keepalive Interval (seconds) : 8
    Mode : Role-based
    Vlan-Mode : vlan-extend-disable
    Reserved-Vlan : 4089
    Stewart Smith
  • 5.  RE: Load balancing for dynamic segmentation
    Posted Oct 14, 2021 04:53 AM
    After a little more digging, please ignore my previous post. The issue seems to be that the bucket map always specifies one controller as the UAC
    [ 0] :: 10.x.x.20 10.x.x.21 0.0.0.0 0.0.0.0
    [ 4] :: 0.0.0.0 0.0.0.0 0.0.0.0 0.0.0.0
    [ 8] :: 0.0.0.0 0.0.0.0 0.0.0.0 0.0.0.0
    Bucket Name : TUNNELED_NODE_ESSID
    Bucket Map Active : [0 .. 255]
    [ 0] :: (0, 1, 1) (0, 1, 1) (0, 1, 1) (0, 1, 1) (0, 1, 1) (0, 1, 1)
    [ 6] :: (0, 1, 1) (0, 1, 1) (0, 1, 1) (0, 1, 1) (0, 1, 1) (0, 1, 1)
    [ 12] :: (0, 1, 1) (0, 1, 1) (0, 1, 1) (0, 1, 1) (0, 1, 1) (0, 1, 1)
    [ 18] :: (0, 1, 1) (0, 1, 1) (0, 1, 1) (0, 1, 1) (0, 1, 1) (0, 1, 1)
    [ 24] :: (0, 1, 1) (0, 1, 1) (0, 1, 1) (0, 1, 1) (0, 1, 1) (0, 1, 1)
    [ 30] :: (0, 1, 1) (0, 1, 1) (0, 1, 1) (0, 1, 1) (0, 1, 1) (0, 1, 1)
    [ 36] :: (0, 1, 1) (0, 1, 1) (0, 1, 1) (0, 1, 1) (0, 1, 1) (0, 1, 1)
    [ 42] :: (0, 1, 1) (0, 1, 1) (0, 1, 1) (0, 1, 1) (0, 1, 1) (0, 1, 1)
    Stewart Smith
  • 6.  RE: Load balancing for dynamic segmentation
    Posted Oct 14, 2021 05:33 AM
    Have you configured controller clustering, and do you have an MM (Mobility Master / Mobility Conductor)? MM is a prerequisite for controller clustering.
    From the bucket-map output, it looks like there is no clustering in place.
  • 7.  RE: Load balancing for dynamic segmentation
    Posted Oct 14, 2021 06:06 AM
    Yes there is a cluster with MM. The load balancing works fine for the wireless clients.
    [MDC] *#show lc-cluster group-membership
    Cluster Enabled, Profile Name = "xxxx-Campus-Cluster"
    Redundancy Mode On
    Active Client Rebalance Threshold = 20%
    Standby Client Rebalance Threshold = 40%
    Unbalance Threshold = 5%
    AP Load Balancing: Enabled
    Active AP Rebalance Threshold = 20%
    Active AP Unbalance Threshold = 5%
    Active AP Rebalance AP Count = 50
    Active AP Rebalance Timer = 1 minutes
    Cluster Info Table
    Type IPv4 Address Priority Connection-Type STATUS
    self 10.x.x.20 128 N/A CONNECTED (Leader)
    peer 10.x.x.21 128 L2-Connected CONNECTED (Member, last HBT_RSP 48ms ago, RTD = 0.000 ms)
    Stewart Smith
  • 8.  RE: Load balancing for dynamic segmentation
    Posted Oct 14, 2021 08:58 AM
    What versions have you running on the gateways/controllers? And what on the 2930M switches?
  • 9.  RE: Load balancing for dynamic segmentation
    Posted Oct 14, 2021 09:21 AM
    Controllers are 8.6.0.10
    Switches are 16.10.0009
    Stewart Smith
  • 10.  RE: Load balancing for dynamic segmentation
    Posted Oct 14, 2021 10:07 AM
    Should be good with those versions. There is some good material, also on logging/troubleshooting in the Dynamic Segmentation Inside Out video series, but if you just want to make it work, it may be best to reach out to Aruba Support and let them have a look at your deployment.
  • 11.  RE: Load balancing for dynamic segmentation
    Posted Oct 14, 2021 10:42 AM
    Ok I will raise with TAC. It is a live customer site with over 50 switch stacks. I am assured that it did previously load balance correctly
    Stewart Smith
