local controller failed to Join the VMM (CONTROLLER-IP/V6 NOT SET)
This thread has been viewed 35 times
  • 1.  local controller failed to Join the VMM (CONTROLLER-IP/V6 NOT SET)
    Posted Oct 31, 2019 01:29 PM
    currently the configuration of the network is ,
    VMM is in: 192.168.XX.23
    MD1: 192.168.XX.20
    MD2: 192.168.XX.21
    MD3: 192.168.YY.25 --> this controller is not joining to the VMM, this is indifferent VLAN.
    here: there is no issue with IPsec, given proper IPsec.
    (ArubaMM) *[mynode] #show switches
    All Switches
    IP Address IPv6 Address Name Location Type Model Version Status Configuration State Config Sync Time (sec) Config ID
    192.168.XX.23 None ArubaMM Building1.floor1 master ArubaMM-VA 8.4.0.2_70086 up UPDATE SUCCESSFUL 0 174
    192.168.XX.20 None Aruba7008MD1 Building1.floor1 MD Aruba7008 8.3.0.4_67604 up UPDATE SUCCESSFUL 10 174
    192.168.XX.21 None Aruba7008MD2 Building1.floor1 MD Aruba7008 8.3.0.4_67604 up UPDATE SUCCESSFUL 9 174
    192.168.YY.25 None Aruba7008MD3 Building1.floor1 MD Aruba7008 8.3.0.2_66308 up CONTROLLER-IP/V6 NOT SET(aa:bb:cc:dd:ee:ff) N/A N/A
    Total Switches:4
     please help me to resolve this issue.
  • 2.  RE: local controller failed to Join the VMM (CONTROLLER-IP/V6 NOT SET)
    Posted Apr 13, 2021 05:48 PM
    Just wondering if you were able to resolve this issue and if so how did you do so?
    I faced the same problem today.
    James Nolan
  • 3.  RE: local controller failed to Join the VMM (CONTROLLER-IP/V6 NOT SET)
    MVP EXPERT
    Posted Apr 14, 2021 04:02 AM
    At both of the MM and MD level was the option to configure a IPv6 address set?
    Craig Syme
  • 4.  RE: local controller failed to Join the VMM (CONTROLLER-IP/V6 NOT SET)
    Posted Apr 15, 2021 05:32 AM
    Hi Craig,
    IPV6 was not set on any of the devices, the new MDs are appearing on the MM but they wont pull the config from the MM and join the cluster.
    James Nolan
  • 5.  RE: local controller failed to Join the VMM (CONTROLLER-IP/V6 NOT SET)
    Posted Jun 14, 2022 11:18 AM
    Hey, did anyone get this fixed? I have the same issue with 8.6.0.11 on a 7005 controller and vmm
    Ambidexter
  • 6.  RE: local controller failed to Join the VMM (CONTROLLER-IP/V6 NOT SET)
    Posted Jun 16, 2022 08:54 AM
    I found the answer!
    You have to make sure the VLAN / IP of the controller shows up in MD>System->Controller IP Address. Check the MAC address and IP and/or VLAN ID that the controller uses to connect to the rest of the network.
    Ambi
    Ambidexter
  • 7.  RE: local controller failed to Join the VMM (CONTROLLER-IP/V6 NOT SET)
    Posted Jun 27, 2022 11:39 PM
    Hi! i have the same problem but in my case the uplink interface is configured by DHCP.
    Building1.floor1 MD ArubaMC-VA 8.10.0.0_83812 up CONTROLLER-IP/V6 NOT SET
  • 8.  RE: local controller failed to Join the VMM (CONTROLLER-IP/V6 NOT SET)
    Posted Jun 27, 2022 11:57 PM
    Please check #6:
    I mean, in retrospect, if you read the error "CONTROLLER-IP/V6 NOT SET", the answer is right there...just make sure the IP is on the System->Controller setting. You just need to say what VLAN to use - if you have a trunk like I do.
    Ambi
    Ambidexter
