Local HA Controllers Move
  • 1.  Local HA Controllers Move
    Posted Dec 21, 2016 04:03 PM
    Fellow Airheads,
    I have a pair of local controllers (7210s) in an HA setup (fast failover with state sync) that I need to move to another site. I will need to re-IP everything at the new location and was wondering if there is a good sequence to move these and also minimize downtime? I was thinking the sequence would be:
    1. Move standby controller
    2. Re-IP and re-configure to be new active, create new AP group with this as primary LMS, and create new HA group
    3. Re-assign APs to new group and cause re-registration to new active- downtime would be limited to AP reboot time
    4. Move former active controller
    5. Re-IP and re-configure to be new standby
    6. Add both controllers to new HA group
    Thoughts? Anyone have a better sequence of events?
  • 2.  RE: Local HA Controllers Move
    Posted Dec 21, 2016 04:44 PM
    Thats a good plan.
    If you are planning on keeping the same config and code for the move , you could also remove the old IP from HA and add the new one of the standby that way the APs will be a standby tunnel to the standby controller and that way if the active controller goes away the APs will transition to the other controller .
    Can the master support APs ?
  • 3.  RE: Local HA Controllers Move
    Posted Dec 21, 2016 06:02 PM
    Yes, the config and code will be the same and will be rejoined to the same master cluster. Since I am using HA, do the LMS and bkup LMS in the system profile no longer matter? I would prefer to keep the same AP group if possible. And yes, I have a 7210 master and am using centralized licensing.
    #AirheadsMobile
