Hi
Im trying to export the local-userdb with the following command:
copy flash: local-userdb-export tftp: x.x.x.x aruba/local-userdb.bin
but it doesnt work. I have a controller running 6.2.0.2 and the command above worked when i run 6.1.2.3
and how should the command be if i want to extract and the send to an tftp server?
local-userdb export <filename>
copy flash: <filename> tftp:<ip address> <filename>
thanks, works perfectly!
