last person joined: 4 hours ago
Local/Master Query
  • 1.  Local/Master Query
    Posted Feb 15, 2013 04:14 PM
    When configuring Local Master , is it done using LMS/Backup LMS on AP or how does AP knows about its master & local , when it first boots it connects to which of them ?
  • 2.  RE: Local/Master Query
    Posted Feb 15, 2013 04:20 PM
    Good evening
    It's based on your AP-SYSTEM-Profile in AP-GROUP that the accesspoints are provisined to.
    configure it here:Untitled.png
    Let us know if it answer your question.
    have a lovley weekend.
    Me
  • 3.  RE: Local/Master Query
    Posted Feb 15, 2013 04:21 PM
    Assuming you have the master-local communication working; the AP will terminate on the controller specified in the primary/backup LMS fields of the AP system profile.   Initial controller discovery is done by one of a few mechanisms; including  DNS lookup (aruba-master.domain.com), DHCP options, or ADP (layer 2 broadcast).
    The 6.2 User Guide discusses the discovery process in depth; starting on page 406. (section attached)
    Attachment(s)
    pdf
    controller_discovery_6.2.pdf   162 KB 1 version
  • 4.  RE: Local/Master Query
    Posted Feb 16, 2013 01:55 AM
    Thanks alot all
    so i understand the following :
    1- Master & local controller communication will be working
    2-  AP discovers controller ( at first boot  i control which controller it sees as its controller using DHCP, DNS..... ) .... This controller can be mastre or local  .... then from it i will provision AP to take LMS & Backup LMS
    3- i can have option to make Local as LMS  & master as backup LMS  , and vice versa
    is the above right ?  as earlier i thought that AP should terminate to Master , then master gives AP its Local controller IP ... and i thought that LMS & Backup LMS is redundancy method not realted at all to master Local Controller
  • 5.  RE: Local/Master Query
    Posted Feb 16, 2013 02:58 AM
    You understood right.
    THE AP will get the needed LMS / BACKUPLMS after the first provising in front of an AP-GROUP , that contatin the info of LMS/BACKLMS in it AP-SYSTEM-PROFILE. (and in thoese configuration u config who is LMS and who is your BACKUPLMS - that ap will get it from there)
    rgrds.
    Me.
  • 6.  RE: Local/Master Query
    Posted Feb 16, 2013 06:00 AM
    Thanks alot .
    and what do u Think is the correct/normal/better  setup ?
    get first  Ip of master while booting as Master then giving LMS IP while provisioning as Local ?
  • 7.  RE: Local/Master Query
    Posted Feb 16, 2013 08:02 AM
    @Telnet-1 wrote:
    Thanks alot .
    It will work either way.
