locate and install VisualRF on my Win7 64-bit.
  • 1.  locate and install VisualRF on my Win7 64-bit.
    Posted Jul 28, 2014 05:49 PM
    I am new to Aruba and want to install VisualRF on my Win7 64-bit laptop. Can't quite locate it from the Aruba website and would like to know if there is any dependence to install it. Thanks in advance.
    Steve
  • 2.  RE: locate and install VisualRF on my Win7 64-bit.
    Posted Jul 28, 2014 06:29 PM
    You'll need to have a valid support contract or be a partner. It'll be located under support.arubanetworks.com under airwave
  • 3.  RE: locate and install VisualRF on my Win7 64-bit.
    Posted Jul 28, 2014 07:02 PM
    Yes. I work for Verizon and we are a partner of Aruba. One time I can locate it and failed to install it. Now, I can't even locate it through their partner support site. BTW, do I need to install installAnywhere to install VisualRF on my laptop? Thanks,
  • 4.  RE: locate and install VisualRF on my Win7 64-bit.
  • 5.  RE: locate and install VisualRF on my Win7 64-bit.
    Posted Jul 29, 2014 03:05 PM
    You shouldn't need anything else other than IE and Java to be able to use VisualRF Plan.
    On the support site, you should see the latest VRF Plan installer when you navigate to Download Software -> AirWave -> VisualRF Plan.
  • 6.  RE: locate and install VisualRF on my Win7 64-bit.
    Posted Jul 29, 2014 06:39 PM
    could you give me the link to your support site? Thanks,
    Steve
  • 7.  RE: locate and install VisualRF on my Win7 64-bit.
    Posted Jul 29, 2014 06:41 PM
    The link to the download is above.
  • 8.  RE: locate and install VisualRF on my Win7 64-bit.
    Posted Jul 29, 2014 06:49 PM
    Thanks. I do locate and download it. Window can't open it. Do you know what progame can help open and install it on my laptop?
  • 9.  RE: locate and install VisualRF on my Win7 64-bit.
    Posted Jul 29, 2014 06:51 PM
    Does it have a file extension? I've seen cases where it gets stripped. Add .exe to the filename then launch it.
