Hello
As far im reading for a good localization 3 APS must see the client
But that make me think that if one AP is serving a specific client, and there are 2 more APs near, they are serving clients in Other channels which means that it should not see the first client of the first AP.
As far i remenber the AP even if its serving clients it goes out of his channel to check other channels, so the 2 APs that are serving on other channel should see the client on which on the other AP
For example
AP 1 got one client ( client Z)which is on channel 36
AP 2 is on channel 40
AP 3 is on channel 44
By now just AP 1 can see client Z
but when the AP 2 goes out of the channel 40 it start looking to see what he can see on other channel but just for a momment which is really fast...
Now that makes me wonder about the accuricity doing that?
It is much better having one AP on Air monitor for example
AP 4 is on air monitor
Will having the AP 4 in air monitor that can also see the client Z on channel 36 is much better choice for accuracity of the location?
When you really need the client location to be really good it is recommended having an ap as air monitor? or this wont help to make it more accurate?
Anyone ? :) Rob? :)
Cheers
Carlos
