Location Based Reporting
  • 1.  Location Based Reporting
    Posted Aug 14, 2016 06:12 AM
    Hello Dears,
    From an MC 7200, can we generate monthly reports, for Data Consumption, per group (Clusters) of AP's?
    The idea is, customer wants to use this data for revenue management, that's by knowing how much Data (GB) was consumed by a certain region, per month - Each reagion will consist of a group of AP Clusters.
    Is this possible directly from MC 7200; without AirWave?
    Thanks.
  • 2.  RE: Location Based Reporting
    Posted Aug 14, 2016 07:48 AM
    Unfortunately, the controller is an appliance with limited historical information.  The controller would have total traffic since an AP has been up, but there is nothing to correlate it to a specific period of time.  This is where Airwave would come in.
  • 3.  RE: Location Based Reporting
    Posted Aug 14, 2016 08:28 AM
    Thanks Colin.
    But with AirWave:
    > Assume Clusters (1,2,3) are in Region A.
    > Clusters (4 - 10) are in Region/City B
    Then, with AirWave we can have seperate monthly reporting for Region/City A, and another one for Region B?
    The main statistics they want are Data Traffic usage per month.
    Thanks a lot.
  • 4.  RE: Location Based Reporting
    Posted Aug 14, 2016 11:26 AM
    If you separate the APs into folders, you can run a report on a "folder" in Airwave to achieve that.
