Location Based Services in Controller and AAA
  • 1.  Location Based Services in Controller and AAA
    Posted Jun 06, 2015 12:08 PM
    I have a single SSID on my network and i want to offer LBS. How i can configure the LBS services based on AAA. I think that ap-group is the best option but the point is how my AAA will read ap-group attribute in order to decide which service should be allowed based on the ap-group. I need to know which AAA attribute will help to learn the ap-group in radius request?
    Which AAA attribute i should use to get the ap-group information from controller in AAA request?
  • 2.  RE: Location Based Services in Controller and AAA
    Posted Jun 06, 2015 12:13 PM
    The AP group and AP name are both sent in the radius request. Which RADIUS server are you using?
    Tim
  • 3.  RE: Location Based Services in Controller and AAA
    Posted Jun 06, 2015 12:17 PM
    Thanks for your kind reply,
    As of now any AAA just consider as standered AAA server which can authenticate any radius request.
    I agree we are sending both but i need to hit the policy based on ap-group. which attribute of aaa i should consider it.
  • 4.  RE: Location Based Services in Controller and AAA
    Posted Jun 06, 2015 12:35 PM
    We would need to know what kind of radius server you are using in order to help.
    Tim
  • 5.  RE: Location Based Services in Controller and AAA
    Posted Jun 07, 2015 01:28 AM
    It is Accuries AAA
  • 6.  RE: Location Based Services in Controller and AAA
    Posted Jun 07, 2015 07:49 AM
    Ali Haider,
    The radius attribute you are looking for is the Aruba-AP-Group attribute.  The Value is attribute Number 10 and Aruba is Vendor ID 14823.  Aruba sends the Ap-Group as a string value in authentication requests to the radius server.  If you can configure your radius server to identify that value, you might be able to accomplish what you want:
    (Aruba7640-US) #show aaa radius-attributes | include Aruba
    Aruba-Auth-SurvMethod             39     Integer      Aruba      14823
    Aruba-Mdps-Max-Devices            18     Integer      Aruba      14823
    Aruba-CPPM-Role                   23     String       Aruba      14823
    Aruba-Mdps-Device-Version         21     String       Aruba      14823
    Aruba-AirGroup-Shared-User        25     String       Aruba      14823
    Aruba-Device-Type                 12     String       Aruba      14823
    Aruba-Mdps-Device-Imei            16     String       Aruba      14823
    Aruba-AP-Group                    10     String       Aruba      14823
    Aruba-Named-User-Vlan             9      String       Aruba      14823
    Aruba-Mdps-Device-Serial          22     String       Aruba      14823
    Aruba-Mdps-Device-Name            19     String       Aruba      14823
    Aruba-AS-User-Name                29     String       Aruba      14823
    Aruba-AS-Credential-Hash          30     String       Aruba      14823
    Aruba-Auth-Survivability          28     String       Aruba      14823
    Aruba-Framed-IPv6-Address         11     String       Aruba      14823
    Aruba-Priv-Admin-User             3      Integer      Aruba      14823
    Aruba-AirGroup-Version            38     Integer      Aruba      14823
    Aruba-WorkSpace-App-Name          31     String       Aruba      14823
    Aruba-Template-User               8      String       Aruba      14823
    Aruba-Location-Id                 6      String       Aruba      14823
    Aruba-Mdps-Device-Profile         33     String       Aruba      14823
    Aruba-AirGroup-Shared-Group       35     String       Aruba      14823
    Aruba-AirGroup-User-Name          24     String       Aruba      14823
    Aruba-Network-SSO-Token           37     String       Aruba      14823
    Aruba-AirGroup-Shared-Role        26     String       Aruba      14823
    Aruba-Mdps-Device-Iccid           17     String       Aruba      14823
    Aruba-Port-Id                     7      String       Aruba      14823
    Aruba-No-DHCP-Fingerprint         14     Integer      Aruba      14823
    Aruba-Mdps-Provisioning-Settings  32     String       Aruba      14823
    Aruba-Mdps-Device-Product         20     String       Aruba      14823
    Aruba-User-Vlan                   2      Integer      Aruba      14823
    Aruba-AirGroup-Device-Type        27     Integer      Aruba      14823
    Aruba-User-Group                  36     String       Aruba      14823
    Aruba-AP-IP-Address               34     IP Addr      Aruba      14823
    Aruba-Mdps-Device-Udid            15     String       Aruba      14823
    Aruba-Admin-Role                  4      String       Aruba      14823
    Aruba-User-Role                   1      String       Aruba      14823
    Aruba-Essid-Name                  5      String       Aruba      14823
