last person joined: 10 hours ago
location "Building1.floor1"
  • 1.  location "Building1.floor1"
    Posted Sep 16, 2013 04:23 PM
    How do I set or change the "location" of the running config?  (location "Building1.floor1").  Or just get rid of it all together.
  • 2.  RE: location "Building1.floor1"
    MVP EXPERT
    Posted Sep 16, 2013 04:40 PM
    If you wish to remove the location then select "remove fqln" when provisioning the AP. if not enter the buildings/floors in visualrf and update accordingly.
  • 3.  RE: location "Building1.floor1"
    MVP
    Posted Sep 17, 2013 05:43 PM
    If you mean the controller location, you can change this through the GUI via:
    Configuration > Network-Controller> Look for the controller location setting in here.
    Via the cli just enter the following command:
    configure terminal location "whatever you want here"
