I am adding three png files.
shows where airwave thinks the device is. I move it to the correct location and check the set static location and click save. This is
Then when I click to show one level up and comeback down one level It is moved to the lower right hand corner as in
airwave three.png.
If I uncheck the box it will then go back to where it was in the beginning.
