Location specific authentication servers
  • 1.  Location specific authentication servers
    Posted 13 days ago
    Is it possible to select an authentication server based on the controller used?
    I have a 4 node CPPM cluster, authenticating to a primary and backup AD controller on our main campus. One of those nodes is on a remote campus, and I'd like to have it use a local AD controller rather than authenticating across the WAN.
    I can create a unique authentication server, and I can create a unique service to use it based on the NAS ID, but is there a better and less manual way?
    This is for eduroam, so switching from passwords to certificates is not an option.
  • 2.  RE: Location specific authentication servers
    Posted 13 days ago
    The topic "Adding a Password Server" is what I think you are after.
    https://www.arubanetworks.com/techdocs/ClearPass/6.12/PolicyManager/Content/CPPM_UserGuide/Admin/ServerConfig_editsystemtab.htm#B926210353
    Carson Hulcher, ACEX#110
  • 3.  RE: Location specific authentication servers
    Posted 13 days ago
    Thanks Carson. That will take care of it for authentications.
    Now if I understand correctly, the AD domain connection is only used for MSCHAPV2 logins. All the attributes are pulled using LDAP from the AD server(s) in the authentication source. I think I can do some geo-dns hacks to make that work.
    Friday is funday. :)
  • 4.  RE: Location specific authentication servers
    Posted 13 days ago
    Set your Auth Source primary target to the domain name rather than a specific DC, DNS should return a result based on the configured site.
  • 5.  RE: Location specific authentication servers
    Posted 12 days ago
    Well that's simply too logical.
    Thanks!
    Andrew
