Wired Intelligent Edge
Log CRC/FCS errors in SysLog
  • 1.  Log CRC/FCS errors in SysLog
    Posted May 17, 2023 01:42 PM
    Hello all, I was looking at a way to send logs to a syslog server that would help identify if a port starts to show high crc/fcs errors. I know I can go into the switch manually and review it. But, I would like to find a way to be alerted when that happens. I attempted to look through the Logging guide and nothing stood out directly to me.
    Figured I would try here. Any help is apprecaited.
    Donald
  • 2.  RE: Log CRC/FCS errors in SysLog
    Posted May 18, 2023 01:40 AM
    is this for a CX switch?
  • 3.  RE: Log CRC/FCS errors in SysLog
    Posted May 18, 2023 06:38 PM
    This is for an CX 8360v2, 6300, and 6200 😁
  • 4.  RE: Log CRC/FCS errors in SysLog
    Posted May 18, 2023 06:47 PM
    i am not sure about SYSLOG giving you that specific info, but you can have a NAE agent for that.
  • 5.  RE: Log CRC/FCS errors in SysLog
    Posted May 23, 2023 08:23 AM
    If you look at this example:
    https://ase.arubanetworks.com/solutions/id/275
    It includes the following:
    • When rate of Rx CRC error packets (packets/s) is above the threshold:
    The agent status is marked as critical & syslog message displayed.
    I've tested these scripts and using the webui on switches it was easy to setup. I haven't tried it on all the models you mention and don't know the limitations. If NAE isn't available then a SNMP monitoring solution would work. We get alarms from switches to IMC (via standard syslog/snmp).
  • 6.  RE: Log CRC/FCS errors in SysLog
    Posted Jun 01, 2023 02:48 PM
    this is for a CX 8360v2, 6300, 6200
